Full Version: Error: WARNING: File is larger than 32bit
Just started my XBMC (which I love Nod) 9.04 to see a movie, and I am just getting "To many consecutive errors", the reason being this line in the log it seems:
21:18:10 T:3280 M:1179668480 WARNING: WARNING: File is larger than 32bit stat can handle, file size will be reported as 0 bytes
Why? I am mapping a drive from my NSLU2, this has worked for ages, and suddenly it is a no go...Stare
The complete log for astartup + 2 movie playback attempts:
21:17:39 T:3076 M:1210638336 NOTICE: -----------------------------------------------------------------------
21:17:39 T:3076 M:1210613760 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on May 5 2009 (SVN:19952, compiler 1500)
21:17:39 T:3076 M:1210613760 NOTICE: Intel® Pentium® M processor 1.60GHz
21:17:39 T:3076 M:1210613760 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
21:17:39 T:3076 M:1210613760 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
21:17:39 T:3076 M:1210609664 NOTICE: special://masterprofile/ is mapped to: C:\Program Files\XBMC\userdata
21:17:39 T:3076 M:1210609664 NOTICE: special://home/ is mapped to: C:\Program Files\XBMC
21:17:39 T:3076 M:1210609664 NOTICE: special://temp/ is mapped to: C:\Program Files\XBMC\cache
21:17:39 T:3076 M:1210609664 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
21:17:39 T:3076 M:1210609664 NOTICE: Log File is located: C:\Program Files\XBMC\xbmc.log
21:17:39 T:3076 M:1210609664 NOTICE: -----------------------------------------------------------------------
21:17:39 T:3076 M:1210585088 NOTICE: Setup SDL
21:17:39 T:3076 M:1209896960 NOTICE: load settings...
21:17:39 T:3076 M:1209880576 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:17:39 T:3076 M:1209876480 NOTICE: loading special://masterprofile/guisettings.xml
21:17:39 T:3076 M:1209597952 NOTICE: Getting hardware information now...
21:17:39 T:3076 M:1209597952 NOTICE: Checking resolution 10
21:17:39 T:3076 M:1209597952 NOTICE: Setting autoresolution mode 12
21:17:39 T:3076 M:1209540608 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
21:17:39 T:3076 M:1209540608 NOTICE: Default DVD Player: dvdplayer
21:17:39 T:3076 M:1209540608 NOTICE: Default Video Player: dvdplayer
21:17:39 T:3076 M:1209540608 NOTICE: Default Audio Player: paplayer
21:17:39 T:3076 M:1209593856 NOTICE: special://masterprofile/sources.xml
21:17:39 T:3076 M:1204142080 NOTICE: GL_VENDOR = ATI Technologies Inc.
21:17:39 T:3076 M:1204133888 NOTICE: GL_RENDERER = MOBILITY RADEON X300 x86/SSE2
21:17:39 T:3076 M:1204133888 NOTICE: GL_VERSION = 2.0.5077 WinXP Release
21:17:39 T:3076 M:1204133888 NOTICE: GL_EXTENSIONS = GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_blend_square GL_NV_occlusion_query GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
21:17:40 T:3076 M:1202716672 NOTICE: start dvd mediatype detection
21:17:40 T:3076 M:1202696192 NOTICE: initializing playlistplayer
21:17:40 T:3076 M:1202692096 NOTICE: DONE initializing playlistplayer
21:17:40 T:3076 M:1202683904 NOTICE: load default skin:[PM3.HD]
21:17:40 T:3076 M:1195671552 NOTICE: initialize done
21:17:40 T:3076 M:1195737088 NOTICE: Running the application...
21:17:40 T:3076 M:1195040768 NOTICE: Webserver: Starting...
21:17:40 T:1476 M:1194868736 NOTICE: Webserver: Started
21:17:40 T:3076 M:1194856448 NOTICE: ES: Starting event server
21:17:40 T:3164 M:1194770432 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:17:40 T:3164 M:1194762240 NOTICE: UDP: Listening on port 9777
21:18:04 T:3076 M:1179975680 NOTICE: DVDPlayer: Opening: M:\Video\Movies\Action\Max Payne.iso
21:18:04 T:3076 M:1179963392 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:18:04 T:3244 M:1179942912 NOTICE: Creating InputStream
21:18:04 T:3244 M:1179820032 WARNING: WARNING: File is larger than 32bit stat can handle, file size will be reported as 0 bytes
21:18:04 T:3244 M:1179779072 ERROR: Error on dvdnav_open
21:18:04 T:3244 M:1179774976 ERROR: CDVDPlayer::OpenInputStream - error opening [M:\Video\Movies\Action\Max Payne.iso]
21:18:04 T:3244 M:1179774976 NOTICE: CDVDPlayer::OnExit()
21:18:04 T:3244 M:1179774976 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:18:04 T:3076 M:1179774976 ERROR: Playlist Player: skipping unplayable item: 0, path [M:\Video\Movies\Action\Max Payne.iso]
21:18:04 T:3076 M:1179766784 NOTICE: CDVDPlayer::CloseFile()
21:18:04 T:3076 M:1179766784 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:18:04 T:3076 M:1179766784 NOTICE: DVDPlayer: waiting for threads to exit
21:18:04 T:3076 M:1179766784 NOTICE: DVDPlayer: finished waiting
21:18:10 T:3076 M:1179680768 NOTICE: DVDPlayer: Opening: M:\Video\Movies\Action\Hell Ride.iso
21:18:10 T:3076 M:1179676672 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:18:10 T:3280 M:1179660288 NOTICE: Creating InputStream
21:18:10 T:3280 M:1179627520 ERROR: Error on dvdnav_open
21:18:10 T:3280 M:1179627520 ERROR: CDVDPlayer::OpenInputStream - error opening [M:\Video\Movies\Action\Hell Ride.iso]
21:18:10 T:3280 M:1179627520 NOTICE: CDVDPlayer::OnExit()
21:18:10 T:3280 M:1179627520 NOTICE: CDVDPlayer::OnExit() deleting input stream
21:18:10 T:3076 M:1179627520 ERROR: Playlist Player: skipping unplayable item: 0, path [M:\Video\Movies\Action\Hell Ride.iso]
21:18:10 T:3076 M:1179631616 NOTICE: CDVDPlayer::CloseFile()
21:18:10 T:3076 M:1179631616 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:18:10 T:3076 M:1179631616 NOTICE: DVDPlayer: waiting for threads to exit
21:18:10 T:3076 M:1179631616 NOTICE: DVDPlayer: finished waiting
Max Payne.iso = 4571734 KB
Hell Ride.iso = 4550524 KB
Solved - This was actually a rights issue on the file(s) on my NSLU2. After setting the rights right Nod i was able to play all files.
