Hi all,
Any update on this topic? I'm experiencing the same issue (ie XBMC crashing, "exiting with error code 11") when playing some .iso files. All of them play perfectly on my MacBook Pro (10.5.8), reading the files from the same smb source (NAS). I'd exclude an issue related to the NAS.
I'm running aTV 3.0.1 and XBMC 9.11 (was the same with XBMC 9.04). Tried also with Boxee and I get the same exact result (crash with error code 11) with the same .iso files.
Already tried some hints found online but with no luck :mad:
Any suggestion?
-- added logs (with debugging ON) from xbmc.log:
! HERE IS WHEN I CLICK ON THE .ISO FILE FOR PLAYING IT
23:37:31 T:2684407808 M: 33034240 DEBUG: new file set audiostream:0
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerCoreFactory::GetPlayers(smb://<omitted>/public/video/Film/DVD/_no_mastz/[DVD-ITA] Il Moralista.iso)
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: dvdimage
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: adding player: videodefaultdvdplayer (1) for rule: dvdimage
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
23:37:31 T:2684407808 M: 33034240 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
23:37:31 T:2684407808 M: 32768000 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
23:37:31 T:2684407808 M: 32768000 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
23:37:31 T:2684407808 M: 32768000 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
23:37:31 T:2684407808 M: 32768000 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
23:37:31 T:2684407808 M: 31526912 DEBUG: CGUIAudioManager:
eInitialize
23:37:32 T:2684407808 M: 31535104 NOTICE: DVDPlayer: Opening: smb://<omitted>/public/video/Film/DVD/_no_mastz/[DVD-ITA] Il Moralista.iso
23:37:32 T:43918336 M: 31543296 DEBUG: thread start, auto delete: 1
23:37:32 T:2684407808 M: 31543296 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
23:37:32 T:48744448 M: 31539200 DEBUG: thread start, auto delete: 0
23:37:32 T:48744448 M: 31539200 NOTICE: Creating InputStream
23:37:32 T:48744448 M: 31535104 INFO: msg: libdvdnav: Using dvdnav version 4.1.3
23:37:32 T:48744448 M: 31535104 INFO: msg: libdvdread: Using libdvdcss version 1.2.10 for DVD access
23:37:32 T:48744448 M: 31518720 DEBUG: CFileSMB::Open - opened public/video/Film/DVD/_no_mastz/[DVD-ITA] Il Moralista.iso, fd=10001
23:37:32 T:48744448 M: 31502336 INFO: msg: libdvdnav: vm: DVD Title: IL_MORALISTA
23:37:32 T:48744448 M: 31510528 INFO: msg: libdvdnav: Unable to find map file '/Users/frontrow/.dvdnav/IL_MORALISTA.map'
23:37:32 T:48744448 M: 31502336 INFO: msg: libdvdnav: DVD disk reports itself with Region mask 0x00c00000. Regions:
23:37:32 T:48744448 M: 31510528 INFO: msg: 1
23:37:32 T:48744448 M: 31510528 INFO: msg: 2
23:37:32 T:48744448 M: 31510528 INFO: msg: 3
23:37:32 T:48744448 M: 31510528 INFO: msg: 4
23:37:32 T:48744448 M: 31510528 INFO: msg: 5
23:37:32 T:48744448 M: 31510528 INFO: msg: 6
23:37:32 T:48744448 M: 31510528 DEBUG: msg:
23:37:32 T:48744448 M: 31510528 DEBUG: Open - Setting region mask 3f
23:37:32 T:48744448 M: 31510528 NOTICE: DVDPlayer: playing a dvd with menu's
23:37:32 T:48744448 M: 31510528 NOTICE: Creating Demuxer
23:37:35 T:43918336 M: 6254592 DEBUG: ------ Window Init (DialogProgress.xml) ------
23:37:35 T:43918336 M: 6254592 DEBUG: Alloc resources: 0.59ms (0.00 ms skin load)
-bash-2.05b$
HERE IS WHEN XBMC EXITS (CRASHES) WITH ERROR CODE 11 - END OF LOG FILE
