How can I get the currently select or list tv show full path in viewType_Multiplex since this:
$INFO[listitem.path]
is not working ?
almost all listitem controls are for music and movies no for tv show why is that ?
and whats the difference between:
Fanart.Image and Listitem.Property(Fanart_Image)
two bumps BEFORE a single day has passed.
just for that you'll have to rot for two days before i even consider to answer
so you was waiting for me to make two bumps ?
If I let more days to pass the thread would be lost,when I make the last post it was in the second page, if after 63 views someone know the answer why it didnt post it ?
Thanks I will rot then
fanart.image is the container's fanart (tvshows)
listitem.property(fanart_image) is the listitem's fanart (typically used with movies, but also tvshows in the tvshow node).
i fixed listitem.path for tvshows in the library @ r21005
please, show some patience. if your post pops off the front page, that might just MIGHT be a hint that your choice of subforum was not the best one
sorry man, the next time what would be the best subforum for this ?
Quote:@ r21005
if that is a revision, sorry for the question but where I can found it ?
i'd say this is skin development related.
anyways, for the record; i woke up, got to work, saw your post (with one bump already) and planned to look at it when i got back home, then you bumped it again.
it's in svn, you have to build or wait for a build for your platform to be available
Quote:it's in svn
Hey, Thanks a lot spiff, I upgrade to svn 21020 and everything is fine now!
I just wanted to pull a different fanart from the one in the background to use in the multiplex tvshow view and I did it:
sample:
What I want now is be able to do <texture diffuse=" " > so I can mask that image to match the tv panels, but is not working.
**If is necessary can a MOD move this thread to a more appropiate one so I dont have to make a new one.
