Full Version: [RELEASE] Luemmel's DVD-Ripper (Script) for Linux, Mac, and Windows
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
Can someone help me!
I can get everything working via putty commandline but when i run the script via xbmc i get script error.
Here's my xbmc log
http://pastebin.com/m288ed5d2
AuXBoX Wrote:Can someone help me!
Here's my xbmc log
Go to the settings and replace ssh-command user@localhost with xbmc@localhost
and it should run fine ....
I guess you are using the linux user xbmc as your default user ....
Regards
Hans
it still doesnt work and now when i execute the script in xbmc i get script error but theres now error logging in dvdripper
heres the xbmc log
http://pastebin.com/m2911179
actually i got a log in dvdripper now
it says
ssh_askpass: exec(/usr/bin/ssh-askpass): No such file or directory
Host key verification failed.
sorry i missed the section
Configure SSH for the script
is there no progress bar?
AuXBoX Wrote:actually i got a log in dvdripper now
it says
do change inside a terminal to root with the following command
sudo -s
After the password do type :
apt-get install ssh-askpass
CU Hans
AuXBoX Wrote:sorry i missed the section
If youn run the script over ssh there is no progress-bar on the operation.
If you run the xbmc python script , you have a progress bar ..
Hans
BTW : Today is my Birthday ;-)
happy birthday !!!!
i have been running it via the scripts menu on xbmc
but still nothing
Is there a way to have the ripped dvd put in a folder?
Ok now when i select rip a dvd to iso i get script error
here's the xbmc log
http://pastebin.com/m384b5260
AuXBoX Wrote:Ok now when i select rip a dvd to iso i get script error
here's the xbmc log
iso_path = os.getenv("HOME") + '/RIPPING_SIZE'
f = open(iso_path,'r')
size_of_rip = int(f.readline())
f.close
After a rip is successfull start you should have a file called RIPPING_SIZE inside your
home directory. If this file not you have a script error ...
Try the following :
go the ssh-directory and type the command
dvd2size.sh /dev/sr0
the output should be the iso-file size in bytes ...
Regards
Hans
It works now thanks.
Is there an easy way to change the output of handbrake? I'm just trying to get a mkv with ac3 or mp4 with multiple aac channels instead of the default 2 channels
I've tried changing the mp4.sh file and then chmod the file again but it never works after that and i have to go back to the original mp4.sh file.
There seems to be no progress bar when transcoding, is it possible to have one?
I think my problem is that i'm editing the mp4.sh in windows
First and foremost thank you Hans for this brilliant script. I think I'm very close to having it working (all dependencies are ok; iso ripping works perfectly) but am getting the following error when I try to transcode:
global name '_language__' is not defined
Here's my xbmc.log:
http://pastebin.com/m2f6fb321
I'm guessing this is a relatively simple issue but I'm thoroughly n00b; apologies in advance. Any help immensely appreciated.
