Full Version: [RELEASE] Luemmel's DVD-Ripper (Script) for Linux, Mac, and Windows
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
There is allready a screenshoot of version 0.6C for linux
http://code.google.com/p/luemmels-dvd-ri...g&can=2&q=
You see the red-pill icon and the main-menu ....
You may see the difference ... I call them now ripper and not only dvd-ripper
The progress on the way to 0.6C could be watched here
http://code.google.com/p/luemmels-dvd-ri...rogress06C
Regards
Hans
luemmel. this is fantastic work. in my opinion this is the best feature built for xbmc so far. we look forward to your progress and I can't wait to test the new release.
adave Wrote:luemmel. this is fantastic work. in my opinion this is the best feature built for xbmc so far. we look forward to your progress and I can't wait to test the new release.
Did you allready donwloaded my created debian packages ?
I saw on the download site of my project that only 1 download was made.
I guees I need some feedback to know that the 2 packages are ok ....
Are they running on a 64 System ?
I made the packages for 32 Bit ....
On request I would also make a 64 bit release .....
Regards from switzerland
Hans
ps : Switzrland should called Land of Rain ....
Hello Users
I would like to know how many of you have a seperate dvd and a bluereay ?
Should I add a seperate section for the blueray-device inside the settings ?
Or should I use the device definition inside the configuration for dvd and blueray operations ?
Regards
Hans
Hello Users
I guess there are 2 ways to transcode a blueray to mkv.
- Complet disc with all chapters .... (needs a lot more of space compared to a single chapter)
- Or only a selected chapter ..... But this leeds me to a problem ..
With the commandline interface from makemkvcon I see only how-many chapters are on disc.
- I don't see the duration of the track
- I don't see the audio-Languages within the track
Has someone a stupid trick to show the track info ?
In the gui duration of a track is showed ....
Should I use chapter mode or dumping the complet blueray ?
Regards from a country where the rain never ends ....
Hans
linuxluemmel Wrote:Hello Users
Regards
Hans
Hi Hans. In my case (as well as a few friends), we all have one device that does DVD and Bluray. So I can think the device definition inside the configuration for bluray operations is ok.
linuxluemmel Wrote:Did you allready donwloaded my created debian packages ?
Hans
I just downloaded the deb packages this morning and will install them later today and report feedback on the packages. I am using a 32-bit version of Ubuntu on my XBMC machine.
Hans
I think this question could be answered by the people the on the MakeMKV forums. Here is the link for the Linux community. http://www.makemkv.com/forum2/viewforum.php?f=3
If you'd like, I could pose the question there as well. Please let me know.
adave Wrote:I think this question could be answered by the people the on the MakeMKV forums. Here is the link for the Linux community. http://www.makemkv.com/forum2/viewforum.php?f=3
In the meantime I found a solution .....
I can read the tracklist over the internal webserver from makemkv and the 2 shell scripts for blueray handling are allmost finished ....
So the non-gui part is done ...
I could later produce a package with the 2 shell scripts and 2 makemkv debian packages ...
My collection of bluerays is very huge .. (just 2 No)
If the non gui part could be tested by a lot of poeple would be fine ...
Regards
Hans
Ok I made it ... (;_)
I guess the realy hard part is done ....
The linux shell-functions for blueray are ready to test ......
http://luemmels-dvd-ripper.googlecode.co...-shell.tar
How could someone test the functions ?
Easy unpack the tar inside a directory of your home directory ...
Be sure to have a directory ~/dvdripper and /dvdrip
go to a terminal and execute the following ....
sudo -s
As soon you are root .... do
apt-get install lynx build-essential libc6-dev libssl-dev libgl1-mesa-dev libqt4-dev libbz2-1.0 libgcc1 libstdc++6 zlib1g
now we install the 2 debian packages for 32 Bit Ubuntu
dpkg -i makemkv-v1.5.6-beta-bin_20100613-1_i386.deb
dpkg -i makemkv-v1.5.6-beta-oss_20100613-1_i386.deb
now exit the root shell and go back to our user-account
there a 2 functions to test
change to the directory where you unpacked the tar
By now the command makemkv should startet.
Put in the licence-key into the menu register ...
If you don't have a key ..... you can get one here ...
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
./blueray-chapter.sh /dev/sr0
This shell-script should extract the volume-name of the blueray inlcuding the info about all tracks
This generated list will be used inside the script to select the title ....
./blueray-transcode.sh /dev/sr0 /dvdrip 300 1
This would transcode the track 1 (index is starting allways at zero)
on the blueray disk (/dev/sr0) and store the file as /dvdrip/300,mkv
./state.sh
Shows information about a inserted dvd or blueray disc
This is only workaround for problem that I found my new notebook and XBMC 9.11
The python function to return the state of the dvd drive is not working correct ....in any case the return value is 3
adave Wrote:Ah, sorry about that Hans. I assumed you were busy with work or developing another script. Glad to hear you're still working on the ripper. Definitely the most valuable script for XBMC!
Where can I get this debug log? Smile sorry its been a while since i posted Smile
cauzeneffeckt Wrote:Where can I get this debug log? Smile sorry its been a while since i posted Smile
Inside the .xbmc directory is a log ;-)
CU Hans
This is my original post:
I installed your script in the proper location, when I select to RIP, it minimized XBMC. I maximize it and then says ERROR: Script failed!
I checked the dvdripper logs and this is what it says. I have version .6b
blue.txt:
create list of devices
calculate size of rip
cleanup
hstart.exe executed
blue-ends
ddrip.text:
RUNNING DD.EXE
ECHO is on.
ECHO is on.
ECHO is on.
any help would be greatly appreciated.. thanks!
Log:
11:17:59 T:2468 M:1358872576  NOTICE: Desktop Resolution: 1280x1024 32Bit at 60Hz
11:17:59 T:2468 M:1358864384  NOTICE: Running with administrator rights
11:17:59 T:2468 M:1358864384  NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
11:17:59 T:2468 M:1358864384  NOTICE: special://masterprofile/ is mapped to: C:\Program Files\XBMC\userdata
11:17:59 T:2468 M:1358864384  NOTICE: special://home/ is mapped to: C:\Program Files\XBMC
11:17:59 T:2468 M:1358864384  NOTICE: special://temp/ is mapped to: C:\Program Files\XBMC\cache
11:17:59 T:2468 M:1358864384  NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
11:17:59 T:2468 M:1358864384  NOTICE: Log File is located: C:\Program Files\XBMC\xbmc.log
11:17:59 T:2468 M:1358864384  NOTICE: -----------------------------------------------------------------------
11:17:59 T:2468 M:1358839808  NOTICE: Setup SDL
11:17:59 T:2468 M:1358594048  NOTICE: Found mode: 320x200 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 320x240 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 400x300 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 512x384 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 640x400 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 640x480 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 640x480 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 640x480 @ 72.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 640x480 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 800x600 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 800x600 @ 72.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 800x600 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 1024x768 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358589952  NOTICE: Found mode: 1024x768 @ 70.00 - Full Screen
11:17:59 T:2468 M:1358581760  NOTICE: Found mode: 1024x768 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1152x864 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1152x864 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x600 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x720 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x720 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x768 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x768 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x960 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x960 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x1024 @ 60.00 - Full Screen
11:17:59 T:2468 M:1358573568  NOTICE: Found mode: 1280x1024 @ 75.00 - Full Screen
11:17:59 T:2468 M:1358622720  NOTICE: Found mode: 320x200 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358622720  NOTICE: Found mode: 320x240 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358622720  NOTICE: Found mode: 400x300 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358622720  NOTICE: Found mode: 512x384 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358618624  NOTICE: Found mode: 640x400 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358618624  NOTICE: Found mode: 640x480 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358618624  NOTICE: Found mode: 800x600 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358618624  NOTICE: Found mode: 1024x768 @ 60.00 - Full Screen #2
11:17:59 T:2468 M:1358573568  NOTICE: load settings...
11:17:59 T:2468 M:1358557184  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:17:59 T:2468 M:1358557184  NOTICE: loading special://masterprofile/guisettings.xml
11:17:59 T:2468 M:1358331904  NOTICE: Getting hardware information now...
11:17:59 T:2468 M:1358331904  NOTICE: Checking resolution 12
11:17:59 T:2468 M:1358319616  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:17:59 T:2468 M:1358311424  NOTICE: Loaded playercorefactory configuration
11:17:59 T:2468 M:1358303232  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:17:59 T:2468 M:1358303232  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:17:59 T:2468 M:1358303232  NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
11:17:59 T:2468 M:1358303232  NOTICE: Default DVD Player: dvdplayer
11:17:59 T:2468 M:1358303232  NOTICE: Default Video Player: dvdplayer
11:17:59 T:2468 M:1358303232  NOTICE: Default Audio Player: paplayer
11:17:59 T:2468 M:1358336000  NOTICE: special://masterprofile/sources.xml
11:17:59 T:2468 M:1335533568  NOTICE: initializing playlistplayer
11:17:59 T:2468 M:1335529472  NOTICE: DONE initializing playlistplayer
11:17:59 T:2468 M:1335521280  NOTICE: load default skin:[Confluence]
11:17:59 T:2468 M:1326235648  NOTICE: initialize done
11:17:59 T:2468 M:1326235648  NOTICE: Running the application...
11:17:59 T:2468 M:1326219264  NOTICE: ES: Starting event server
11:17:59 T:3608 M:1326145536  NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
11:17:59 T:3608 M:1326137344  NOTICE: UDP: Listening on port 9777
11:18:15 T:3684 M:1325477888  NOTICE: -->Python Interpreter Initialized<--
11:18:15 T:3684 M:1324376064  NOTICE: ------------------------------------------------------------
11:18:15 T:3684 M:1324376064  NOTICE: dvd-blue RC-1 Version: 0.6B Date: 10-29-2009
11:18:15 T:3684 M:1324371968  NOTICE: xbmc language selected : english
11:18:15 T:3684 M:1324371968  NOTICE: path to strings.xml : C:\Program Files\XBMC\scripts\dvd-blue/resources/language/english
11:18:15 T:3684 M:1324371968  NOTICE: path to settings : C:\Program Files\XBMC\scripts\dvd-blue/config/settings
11:18:15 T:3684 M:1324355584  NOTICE: 9.11 r26017
11:18:15 T:3684 M:1324265472  NOTICE: eula was accepted
11:18:20 T:3684 M:1344860160  NOTICE: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\hstart /NOCONSOLE /D="C:\Program Files\XBMC\scripts\dvd-blue" "cmd.exe /c "echo EULA-Accepted > C:\Program Files\XBMC\scripts\dvd-blue\EULA_blue-pill-accepted""
11:18:20 T:3684 M:1344851968  NOTICE: this script will use this default settings :
11:18:20 T:3684 M:1344851968  NOTICE: default dvd-device:[\\?\Device\CdRom0]
11:18:20 T:3684 M:1344851968  NOTICE: default rip-directory:[D:\dvdrip]
11:18:20 T:3684 M:1344851968  NOTICE: default dvd-drive letter :[F:]
11:19:14 T:3684 M:1345953792  NOTICE: windows-part
11:19:35 T:3684 M:1351106560  NOTICE: menu settings selected
11:20:23 T:3684 M:1350180864  NOTICE: windows-part
11:20:23 T:3684 M:1349984256  NOTICE: executed command volname.cmd to get dvd-name .....
11:20:23 T:3684 M:1349984256  NOTICE: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\hstart /NOCONSOLE /D="C:\Program Files\XBMC\scripts\dvd-blue\windows-shell" "cmd.exe /c "C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\volname.cmd D: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell""
11:20:28 T:3684 M:1351741440  NOTICE: Traceback (most recent call last):
11:20:28 T:3684 M:1351741440  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 1539, in ?
11:20:29 T:3684 M:1351708672  NOTICE: mydisplay = MainClass()
11:20:29 T:3684 M:1351708672  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 621, in __init__
11:20:29 T:3684 M:1351708672  NOTICE: state = do_ripp(False)
11:20:29 T:3684 M:1351708672  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 326, in do_ripp
11:20:29 T:3684 M:1351700480  NOTICE: dvd_iso = get_disc_name(DVD_device,DVD_dir,'change-me',True)
11:20:29 T:3684 M:1351700480  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 1474, in get_disc_name
11:20:29 T:3684 M:1351761920  NOTICE: stat_info = os.stat(volume_path)
11:20:29 T:3684 M:1351761920  NOTICE: OSError
11:20:29 T:3684 M:1351761920  NOTICE: :
11:20:29 T:3684 M:1351761920  NOTICE: [Errno 0] Error: 'C:\\Program Files\\XBMC\\scripts\\dvd-blue\\windows-shell\\tmp\\RIPPING_VOLNAME'
11:20:29 T:3684 M:1351761920   ERROR: Scriptresult: Error
11:20:44 T:2468 M:1347694592  NOTICE: Storing total System Uptime
11:20:44 T:2468 M:1347694592  NOTICE: Saving settings
11:20:44 T:2468 M:1347604480  NOTICE: stop all
11:20:44 T:2468 M:1347600384  NOTICE: ES: Stopping event server
11:20:44 T:3608 M:1347559424  NOTICE: ES: UDP Event server stopped
11:20:44 T:2468 M:1347579904  NOTICE: stop sap announcement listener
11:20:44 T:2468 M:1347579904  NOTICE: clean cached files!
11:20:44 T:2468 M:1347571712  NOTICE: unload skin
11:20:44 T:2468 M:1352982528  NOTICE: stop python
11:20:44 T:2468 M:1352982528  NOTICE: stopped
11:20:44 T:2468 M:1352982528  NOTICE: destroy
11:20:44 T:2468 M:1353003008  NOTICE: unload sections
realized that one had the wrong settings on it, here it is after i ran it with the correct settings
11:57:04 T:2912 M:1159712768  NOTICE: dvd-blue RC-1 Version: 0.6B Date: 10-29-2009
11:57:04 T:2912 M:1159712768  NOTICE: ------------------------------------------------------------
11:57:04 T:2912 M:1159708672  NOTICE: xbmc language selected : english
11:57:04 T:2912 M:1159708672  NOTICE: path to strings.xml : C:\Program Files\XBMC\scripts\dvd-blue/resources/language/english
11:57:04 T:2912 M:1159708672  NOTICE: path to settings : C:\Program Files\XBMC\scripts\dvd-blue/config/settings
11:57:04 T:2912 M:1159692288  NOTICE: 9.11 r26017
11:57:04 T:2912 M:1159512064  NOTICE: eula was accepted
11:57:08 T:2912 M:1157394432  NOTICE: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\hstart /NOCONSOLE /D="C:\Program Files\XBMC\scripts\dvd-blue" "cmd.exe /c "echo EULA-Accepted > C:\Program Files\XBMC\scripts\dvd-blue\EULA_blue-pill-accepted""
11:57:08 T:2912 M:1157386240  NOTICE: this script will use this default settings :
11:57:08 T:2912 M:1157386240  NOTICE: default dvd-device:[\\?\Device\CdRom0]
11:57:08 T:2912 M:1157386240  NOTICE: default rip-directory:[C:\DATA\Shortcuts]
11:57:08 T:2912 M:1157386240  NOTICE: default dvd-drive letter :[D:]
11:57:13 T:2800 M:1158430720   ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
11:57:13 T:2800 M:1158430720   ERROR: WEATHER: Weather download failed!
11:57:16 T:2912 M:1158840320  NOTICE: menu settings selected
11:57:29 T:2912 M:1169190912  NOTICE: windows-part
11:57:29 T:2912 M:1181691904  NOTICE: executed command volname.cmd to get dvd-name .....
11:57:29 T:2912 M:1181691904  NOTICE: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\hstart /NOCONSOLE /D="C:\Program Files\XBMC\scripts\dvd-blue\windows-shell" "cmd.exe /c "C:\Program Files\XBMC\scripts\dvd-blue\windows-shell\volname.cmd D: C:\Program Files\XBMC\scripts\dvd-blue\windows-shell""
11:57:34 T:2912 M:1180487680  NOTICE: Traceback (most recent call last):
11:57:34 T:2912 M:1180487680  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 1539, in ?
11:57:34 T:2912 M:1181270016  NOTICE: mydisplay = MainClass()
11:57:34 T:2912 M:1181270016  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 621, in __init__
11:57:34 T:2912 M:1180667904  NOTICE: state = do_ripp(False)
11:57:34 T:2912 M:1180667904  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 326, in do_ripp
11:57:34 T:2912 M:1180647424  NOTICE: dvd_iso = get_disc_name(DVD_device,DVD_dir,'change-me',True)
11:57:34 T:2912 M:1180647424  NOTICE:   File "C:\Program Files\XBMC\scripts\dvd-blue\default.py", line 1474, in get_disc_name
11:57:35 T:2912 M:1167802368  NOTICE: stat_info = os.stat(volume_path)
11:57:35 T:2912 M:1167802368  NOTICE: OSError
11:57:35 T:2912 M:1167802368  NOTICE: :
11:57:35 T:2912 M:1167802368  NOTICE: [Errno 0] Error: 'C:\\Program Files\\XBMC\\scripts\\dvd-blue\\windows-shell\\tmp\\RIPPING_VOLNAME'
11:57:35 T:2912 M:1167802368   ERROR: Scriptresult: Error
11:57:47 T:3184 M:1165176832  NOTICE: Storing total System Uptime
11:57:47 T:3184 M:1165176832  NOTICE: Saving settings
11:57:47 T:3184 M:1165119488  NOTICE: stop all
11:57:47 T:3184 M:1165115392  NOTICE: ES: Stopping event server
11:57:48 T:2876 M:1165721600  NOTICE: ES: UDP Event server stopped
11:57:48 T:3184 M:1165742080  NOTICE: stop sap announcement listener
11:57:48 T:3184 M:1165742080  NOTICE: clean cached files!
11:57:48 T:3184 M:1165733888  NOTICE: unload skin
11:57:48 T:3184 M:1172443136  NOTICE: stop python
11:57:48 T:3184 M:1172443136  NOTICE: stopped
11:57:48 T:3184 M:1172443136  NOTICE: destroy
11:57:48 T:3184 M:1172377600  NOTICE: unload sections
Hello ;-)
I'm still hard working to the milestone 0.6c .....
Here is my changelog ....
12/06/10 0.6C   We   - New Red-pill icon (Thanks to P.Hocher from luxeria.ch )
                     - Info Box was not showing correctly with skin Confluence
                       (Patch was provided by P.Hocher)
                     - Integrate livecd.sh as a new script "setup.sh" inside installer directory
                     - Replace getDVDState API Function with a shell-script ....
                     - Rename Mainmenu-DVD-RIPPER to Mainmenu
                     - Integrate blueray function to main-menu (added ID-32049)
15/06/10        We   - Replace all references from getDVDState to internal function dvd_inserted
                     - Update internal handbrake version 0.9.3 to version 0.9.4
                     - Added handbrake 0.9.4 source-code to the folder
                     - Change needed softare for handbrake 0.9.4 inside setup.sh
                     - Tested handbrake inside Ubuntu 10.04 LTS / 32 Bit
                     - New encode dvd's with handbrake -high-profile mkv and AC3 sound
                       (Thanks to xbmc forum-member hotlobsteer)
                     - Integrate the handbrake settings from doom9 forum
                     - Add missing header for file mp4.sh with all parameters
                     - Changed extension for transcoding h264 from mp4 to mkv
16/06/10       We    - Integrate BusyDialog inside script (had not effect with xbmc 9.11 ... needs xbmc 10.5)
                     - Problem with secound audio stream inside HandBrake fixed
                     - Added chapter breaks inside mkv
19/06/10       We    - rename function drive_no_dvd() to rive_no_disc():
                     - change string id 33051
                     - create shell script to read chapters from blueray [blueray-chapters.sh]
                     - create shell script to transcode a chapter from bluray [bluereay-transcode.sh]
                     - Made the scripts puplic for testing. I hope I have some feedback
23/06/10       We    - Create progress-bar for transcoding blueray-mkv inside shell-script.
                     - Test the progress-bar for transcoding inside shell. works :-)
