Full Version: [RELEASE] Luemmel's DVD-Ripper (Script) for Linux, Mac, and Windows
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
The tar z flag was only missing inside the debian file for makemkv 32 bit ....
I tested the 3 other packages with tar xvzf
makekmkv 64 -> confirmed and tested .-)
handbrake 32 -> confirmed and tested :-)
handbrake 64 -> confirmed and tested :-)
The ugly bug with the state file comes from the missing makemkvcon file inside state.sh
and your choice not to install the bluray part .... (This is not your fault -> It is my fault)
I did search for makemkvcon even if someone did not install the bluray part during setup. .....
I do change the state.sh script that the script only looks for this executable
if no dvd is inserted or the bluray part is activated inside the settings.
Regards
Hans
- I do release 0.6.14 soon-
- It has allready a network script inside to test but not over the gui
- it has a lot of corrections
- More tests on startup
Should we leave the alpha state after the release of 0.6.14 ?
Greetings Hans
linuxluemmel Wrote:Should we leave the alpha state after the release of 0.6.14 ?
i just started testing this but as far as i can see go right ahead into beta Smile
Ok the latest alpha is out ....
0.6.14 can be installed over the repository .....
With the relase of 0.6.15 you can send diff file for other languages than english
and german ... ( I do the german part by my self ... it is my native language)
Please do not send them now ... after release 0.6.15 they are welcome.
According to the statistics from the repository my tool is allready in a wide use ,-)
regards from switzerland
hans
I guess my addon should speak also ...
- french
- spain
- portuges
- Swedish
- Russian
and may a few other ...
I came across your addon and set it up, however I've found a few typos in the section installing makemkv for 32bit systems:
Here are the changes I made to get it to install completely using your setup.sh script.
Line 519 Change
dpkg -i makemkv-v1.5.8-bin_20100818-1_i386.deb
to
dpkg -i makemkv-v1.5.8-bin_20100822-1_i386.deb
Line 530 change
dpkg -i makemkv-v1.5.8-oss_20100818-1_i386.deb
to
dpkg -i makemkv-v1.5.8-oss_20100822-1_i386.deb
Line 541 change
rm xvzf makemkv-v1.5.8-32.tar.gz
to
rm makemkv-v1.5.8-32.tar.gz
Line 610 Change
to
Line 621 change
to
Line 632 change
to
Cheers
F
thanks ... change it asap and repack the zip .-)
OK, new question.
I'm getting the "Configured ssh-user is not current user" error. Where do I change this? I only have one user on this machine as far as I know...
if your username is NOT XBMC then you should change the settings and correct them.
http://code.google.com/p/swiss-army-knife/wiki/FAQ
I just installed the add-on on Xubuntu Linux+Dharma beta and am trying to run the setup.sh. I can't get past the licence question: the script rejects any input I give:
Do you want to accept this enduser-licnce ? (y)y
[: 152: y: unexpected operator
licence was not accepted !
----------------------- script rc=5 -----------------------------
Whatever I reply, I always get the "unexpected operator" response. Any Ideas?
Johan
JohanE Wrote:I just installed the add-on on Xubuntu Linux+Dharma beta and am trying to run the setup.sh. I can't get past the licence question: the script rejects any input I give:
Johan
Found the solution myself: I was running the script using "sh ./setup.sh", but had to use "bash ./setup.sh".
OK I saw it and I asked myself what the hell this means ....
I used this shell-function allready a few times without any problem ...
I have included a test in the next coming release 0.6.15 to prevent
running setup.sh with a other shell than /bin/bash
Regards Hans
So, I got it all installed but I keep getting errors when I start the script: Licence-key for makemkv expired, and various folder "not found or writable".
I installed the current key through the makemkv GUI, and it's correctly written in ~/.MakeMkv/settings.conf. I also created all folders as listed in the add-on settings in my home folder, so they are there and writable. It almost looks like the script is looking at the wrong homedir, so I tried copying the folders to /home/xbmc, to no avail. The correct username is set in the settings and the "Test ssh" in expert mode reports success. Any ideas?
Inside the startup of the script I do look for all the folders that are defined inside
the settings.
Inside the shell-linux folder is a script called check-mkv.sh
Please run this file and report back the output ...
You changed your new directorys to the folders inside your home-dir over the settings ?
Activate debug-log and use a pastebin that we can have a look on it ..
