Full Version: [RELEASE] Luemmel's DVD-Ripper (Script) for Linux, Mac, and Windows
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
Tryed to set it to 4 ( it was set to 1 sec in the script ), but no improvement, still this error:
Error Contents: local variable 'sshlog' referenced before assignment.
Is there a way to force the ssh-check to ok, I'd like to see if everything is working as expected once the check passed.
Cheers
@hotlobster
Could please provide a full debug log including a debug log from SAK ?
Are you using a xbmc build that is using external python ?
In the moment I try to code a parameter to the settings for this timeout ...
Regards
Hans
I provide a svn snapshot of the next coming release 0.6.19 for downloading :
http://swiss-army-knife.googlecode.com/f...032011.zip
It is allmost complet with one execption ; Issue 17 is still not fixed
Could anyone with this ssh-check problem please use this svn-snapshot and
report feedback ?
Regards
Hans
Hi there.
Just installed SAK.
I use Dharma opendkamp pvr not compiled with external python.
So, still have a bug, not the sshlog one, but more python related.
I had this bug yesterday when trying to bypass the sshcheck:
Error Contents: 'ascii' codec can't encode character u'\xe9' in position 41: ordinal not in range(128)
Here is the full debug log:
http://xmltv.free.fr/xbmc.log
It seems there's some problem in ascii/utf8 conversion depending of your configuration.
sys.getdefaultencoding() gives 'ascii'
but
locale.getdefaultlocale() gives ('fr_FR', 'UTF8')
Python by default is set to ascii on Debian, but locale are UTF-8 by default too. Perhaps it's the source of the problem.
Cheers
This looks strange to me ....
Is it true that your xbmc interface has french as default language ?
Nous avons un problème avec la langue
Is it may possible to switch back to english and see if that happens again ?
Regards
Hans
btw It seems that the ssh problem is solved ,-) ( I saw this in the logs...)
Yep my interface is in French.
Those error are related to special characters conversion with Python :
http://docs.python.org/howto/unicode.html
I confirm it works when i fall back in English.
And hell yeah ssh problem is gone. What did you change ?
@hotlobster
Thanks for the feedback anyway ,-)
I guess I know by now were the problem is ....
I wonna try to fix this issue on the next weekend ,-)
For the ssh relatet problems I changed some lines of code .
You can see all the changes I made yesterday in Commit R483
http://code.google.com/p/swiss-army-knif...tail?r=483
@hotlobster
You can still use french as your default language.
Please disable verbose log including notifications over the addon-settings.
As soon this 2 options are disabled -> Voila, c'est bon ,-)
Regards
Hans
I try to iplement this 2 functions unicode save ;-)
Thanks for the tips linuxluemmel Smile
I've tryed the new "use iso instead of dvd" feature, but I don't see how it works.
I've mounted the iso in /dev/dvd with -loop , but the soft keeps telling me drive is not ready.
@hotlobster
This new parameter is inside the settings but has by now effect.
I will implement this feature later. I hope anyone who had this ssh failure
can now work with the addon.
Forgive my newbness, what log do you need and where do i get that.
Im still having ssh issues.
Never mind reran setup everything seems fine.
Seemed fine. Im having blu-ray issues its looks like it wants to start. but never does. just freezes at working. Dvd Starts but it seems to take longer than it has before.
Still getting the language error. I've install 6.19, here is the ssh log entry.
TERM environment variable not set.
script    : state.sh
version   : 0.6.19 [swiss-army-knife addon] [01.03.2011]
copyright : (C) <2010-2011>  <[email protected]>
changed to /home/xbmc/.xbmc/addons/script.video.swiss.army.knife/shell-linux
INFO [media:[DVD-ROM]]
----------------------- script rc=0 -----------------------------
[b]TERM environment variable not set.[/b]
##Hans, what is this?  Could this be the culprit.
script    : dvd-chapter.sh
scipt is using a device as source [/dev/sr0]
INFO track-index:[00] length:[02:41:32.186] chapters:[36]
INFO track-index:[01] length:[00:00:00.176] chapters:[01]
INFO track-index:[02] length:[00:00:00.176] chapters:[01]
INFO track-index:[03] length:[00:00:07.176] chapters:[02]
INFO track-index:[04] length:[00:00:00.176] chapters:[01]
INFO track-index:[05] length:[00:00:07.176] chapters:[02]
INFO track-index:[06] length:[00:00:34.176] chapters:[02]
INFO track-index:[07] length:[00:00:00.176] chapters:[01]
INFO track-index:[08] length:[00:00:43.176] chapters:[02]
INFO track-index:[09] length:[00:00:00.176] chapters:[01]
INFO track-index:[10] length:[00:00:11.143] chapters:[02]
INFO track-index:[11] length:[00:00:05.176] chapters:[02]
INFO track-index:[12] length:[00:00:00.176] chapters:[01]
INFO track-index:[13] length:[00:00:00.176] chapters:[01]
INFO track-index:[14] length:[00:00:00.176] chapters:[01]
INFO track-index:[15] length:[00:00:00.176] chapters:[08]
INFO track-index:[16] length:[00:00:00.176] chapters:[01]
INFO track-index:[17] length:[00:00:10.176] chapters:[03]
INFO track-index:[18] length:[00:00:00.176] chapters:[01]
INFO volume-name of the current inserted dvd is [AVATAR]
INFO automatic selected track from inserted dvd [][line-index]
INFO default language 1 [en]
INFO default language 1 [en] not found inside track []
I've been using mkv, but I prefer yours. Just can't get past the language error.
FYI: If i use expert mode to Ripp DVD to ISO it works, but selecting Trancode DVD from main menu I get the language error. Is Transcode to dvd on main menu just using cmd dd if=/dev/sr0 of=/rip directory file name.iso. I've looked at dvd-chapter.sh and can not pin point what is causing the error.
@speed32219
Is it may possible to insert the same dvd and do this command ...
lsdvd -a
And recopy the output to a pastebin ?
Regards
Hans
lsdvd -a
Can't find device /dev/dvd
lsdvd /dev/sr0 -a
libdvdread: Using libdvdcss version 1.2.10 for DVD access
Disc Title: AVATAR
Title: 01, Length: 02:41:32.186 Chapters: 36, Cells: 46, Audio streams: 04, Subpictures: 04
        Audio: 1, Language: en - English, Format: ac3, Frequency: 48000, Quantization: drc, Channels: 6, AP: 0, Content: Undefined, Stream id: 0x80
        Audio: 2, Language: en - English, Format: ac3, Frequency: 48000, Quantization: drc, Channels: 2, AP: 0, Content: Undefined, Stream id: 0x81
        Audio: 3, Language: es - Espanol, Format: ac3, Frequency: 48000, Quantization: drc, Channels: 2, AP: 0, Content: Undefined, Stream id: 0x82
        Audio: 4, Language: fr - Francais, Format: ac3, Frequency: 48000, Quantization: drc, Channels: 2, AP: 0, Content: Undefined, Stream id: 0x83
Title: 02, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
        Audio: 1, Language: en - English, Format: ac3, Frequency: 48000, Quantization: drc, Channels: 2, AP: 0, Content: Undefined, Stream id: 0x80
Title: 03, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 04, Subpictures: 04
Title: 04, Length: 00:00:07.176 Chapters: 02, Cells: 02, Audio streams: 00, Subpictures: 00
Title: 05, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 00, Subpictures: 00
Title: 06, Length: 00:00:07.176 Chapters: 02, Cells: 02, Audio streams: 00, Subpictures: 00
Title: 07, Length: 00:00:34.176 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 00
Title: 08, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 09, Length: 00:00:43.176 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 00
Title: 10, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 11, Length: 00:00:11.143 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 00
Title: 12, Length: 00:00:05.176 Chapters: 02, Cells: 02, Audio streams: 01, Subpictures: 00
Title: 13, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 14, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 15, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 00
Title: 16, Length: 00:00:00.176 Chapters: 08, Cells: 01, Audio streams: 00, Subpictures: 00
Title: 17, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 00, Subpictures: 00
Title: 18, Length: 00:00:10.176 Chapters: 03, Cells: 03, Audio streams: 00, Subpictures: 00
Title: 19, Length: 00:00:00.176 Chapters: 01, Cells: 01, Audio streams: 04, Subpictures: 04
Longest track: 01
Ops, sorry about the pastebin, I will do that from now on, keeps pages on posts down.
