Looks good, maybe add something about the -j# parameter when building on a #-core machine? And perhaps a caveat that you might need to run make install with sudo?
Stupid question. The ./configure process takes a bit of time. Is it always necessary to do this or can you just update from svn and run "make" once you've run ./configure initially (or is there some indication that a particular pull from svn will require re-running ./configure)?
you may want to add "sudo" in from of 'make install'.
crego; changes to configure and/or configure.in and/or any *.in file in general (Makefiles, some generated source files)
depends on who you ask i guess.
if you ask a power user any tutorial is overkill - you should be able to figure it out on your own based on README.linux and general 'puter/unix stuff. if this is the ground rules we follow we should have NO articles.
then again a lot of people run 'ubuntu', not linux. and the same for other distro's. making it dead simple on them can't hurt.
