Whats the latest version? 3.1.1 is the one that shows up in Eden Beta2 but the live stream is not working. On the XBMC wiki it is referred to 3.1.3... how do I install this? The update button under the NRK addon information page in XBMC is disabled so I'm stuck with 3.1.1.
Just downloaded and installed Eden 11.0 (Compiled: Mar 21 2012) from xbmc.org/downloads but still just 3.1.1 available... hum!
/Christoffer
(2012-04-25, 19:40)AlfaBeta Wrote: [ -> ]Just downloaded and installed Eden 11.0 (Compiled: Mar 21 2012) from xbmc.org/downloads but still just 3.1.1 available... hum!
/Christoffer
Then do a manual 'check for updates' in the addons menu. If that doesn't work, delete it from the addons directory (also addons/package dir). It's definitely in the repo..
Edit: Deleting the Users\%userprofile%\AppData\Roaming\XBMC\ folder and re-installing fixed the problem.
Ok, I now installed XBMC on a different computer. Now I get 3.1.3 and the default settings on menus and so on. There is probably a file somewhere on my media center that is not deleted when I uninstall the old XBMC Eden Beta2 (and the entire Program files > XBMC folder). The new XBMC Eden Final installation is then probably picking up some settings from this old file? Any idea where to look?
If anyone want to try the new version, you can download source code
here. But remember, it's likely very buggy (no need to report bugs yet) and available features and content is limited.
More to come!
Wow, that was fast
Running without problems here so far, just hope that NRK can fix the problems with the flash streams causing high cpu usage even when running in hw accelerated mode.
Thanks for this and keep up the good work
The flash is just on their website. The back-end and this plugin's using pure h264 over hls, fully hw accelerated.
(2012-04-26, 18:30)takoi Wrote: [ -> ]The flash is just on their website. The back-end and this plugin's using pure h264 over hls, fully hw accelerated.
Just noticed that, workiing very well
Also noticed that the programs are playing in beautiful 720P but the live master streams are only SD, any way to fix that?
Yeah, I know the live streams are sd. It's the only thing available atm, but remember: the new service is still early in its beta, so im assuming it will come later..
Should be pretty usable now. Pics, since people love them:
(Will install side-by-side with the old one, so you don't have to worry about loosing content)
And because of the missing content, I don't think I'll add it to the repository until the site is out of beta. Which will probably be at least a few months..
Very nice
Btw you may want to change the live feed links, they are all showing NRK1
ty. fixed. thats what happen when you copy/paste. (use same link as above)
(2012-04-30, 16:26)takoi Wrote: [ -> ]ty. fixed. thats what happen when you copy/paste. (use same link as above)
C&P are a programmers best friend and vorst enemy (sometimes)
Excellent work takoi, thank you
I poke around and here's my findings so far, hope some of it is new to you
1. Is caching when pausing the video now working? I play a 8 minute video and only see a litle bit of gray (indikating how much is caching). Same video length in Youtube give me lots of gray
2. Missing plot from Info
3. In the latest tab, "Samisk barne-tv" have some codes in the beginning of name
4. Bottom of the Thumbnails are black
5. Picture in Info are squeezed
6. Live stream is paused at start
7. Missing subtitles
Thank's that's it for now
