import sys, os
from utils import Key, PluginSettings
from xbmcplugin import addDirectoryItem, endOfDirectory, setResolvedUrl
from xbmcgui import ListItem
from connection_manager import DataHandle
def mms_to_http(url):
return url.replace('mms', 'http')
def mms_url(data):
print data
nurl = ''
for c in data[18:]:
if c != '\r':
nurl += c
else: break
nurl = nurl.replace('http', 'mms')
return nurl
class Main:
CHANNELS = [
('nrk tv direkte', 'mms://straumv.nrk.no/nrk_tv_direkte_nrk1_%s'),
('nrk tv', 'mms://straumV.nrk.no/nrk_tv_nrk1_%s'),
('nrk webvid 1', 'mms://straumv.nrk.no/nrk_tv_webvid01_%s')
def __init__(self):
key = Key( sys.argv[2] )
self.hndl = int(sys.argv[1])
self.success = True
if not key.url:
self.parse_channels()
else:
self.get_stream(key.url)
def get_stream(self, url):
self.get_settings()
self.dman = DataHandle()
url = url % self.settings('connection_speed')
url = mms_to_http( url )
data = self.dman.get_data(url)
url = mms_url(data)
listitem = ListItem( url, path=url)
print 'Play url: %s' % url
setResolvedUrl(self.hndl, self.success, listitem)
def get_settings(self):
self.settings = PluginSettings()
#Connection speed
options = ( 'l', 'm', 'h', ); index = 11
self.settings.add('connection_speed', 'values', options, index)
def parse_channels(self):
for i in self.CHANNELS:
self.add(i[0], i[1])
endOfDirectory(self.hndl)
def add(self, label, url, type='channel', prefix='kanalene', img='', icon='', isdir=False):
url = Key.build_url(prefix, type=type, url=url)
li = ListItem(label, iconImage=icon, thumbnailImage=img)
li.setProperty('IsPlayable', 'true')
ok = addDirectoryItem(self.hndl, url=url, listitem=li, isFolder=isdir)
return ok
