Full Version: Jitter when playing DVDs in XBMC Windows
I am getting jittery video when playing DVDs on disc or DVD ISO files. I have converted all my dvd into ISO files using dvdfab. Basically they are converted into 1 file with a size of 4.7GB to 8GB depending on the source dvd. IN fast moving sequences or when the camera is panning i get a line acrros the middle of the screen as if the upper half of the screen is refreshing faster or slower then the lower half. All movies and videos play perfectly in windows media player. It seems to be a problem with the XBMC player.
I need help do not know what to do at this point. It used to not do this and I do not know when it started happening.
Here is my configuration:
* CORE 2 Duo 2.66GHz
* 6GB DDR3 Ram
* 500GB HD for operating system and programs
* 4TB of HD storage for media (4X1.5TB raid 5) 3ware 9500S
* GIGABYTE ATI RADEON 4850 with 1GB DDR3 -- ATI CCC 9.5 installed
* Video and Audio through HDMI out from video card to receiver to Pioneer Kuro 50 inch Plasma
* Desktop Resolution: 1920x1080 32Bit at 60Hz
* VISTA 64bit Ultimate Service Pack 2
* XBMC 9.04.1
xbmc.log
00:38:58 T:2492 M:4294967295 NOTICE:
00:38:58 T:2492 M:4294967295 NOTICE: Starting XBMC, Platform: Windows Vista, 32-bit Service Pack 2 build 6002. Built on May 26 2009 (SVN:20672, compiler 1500)
00:38:58 T:2492 M:4294967295 NOTICE: Intel® Core™2 CPU 6700 @ 2.66GHz
00:38:58 T:2492 M:4294967295 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
00:38:58 T:2492 M:4294967295 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
00:38:58 T:2492 M:4294967295 NOTICE: special://masterprofile/ is mapped to: C:\Users\media\AppData\Roaming\XBMC\userdata
00:38:58 T:2492 M:4294967295 NOTICE: special://home/ is mapped to: C:\Users\media\AppData\Roaming\XBMC
00:38:58 T:2492 M:4294967295 NOTICE: special://temp/ is mapped to: C:\Users\media\AppData\Roaming\XBMC\cache
00:38:58 T:2492 M:4294967295 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
00:38:58 T:2492 M:4294967295 NOTICE: Log File is located: C:\Users\media\AppData\Roaming\XBMC\xbmc.log
00:38:58 T:2492 M:4294967295 NOTICE: Setup SDL
00:38:58 T:2492 M:4294967295 NOTICE: load settings...
00:38:58 T:2492 M:4294967295 NOTICE: special://profile/ is mapped to: C:\Users\media\AppData\Roaming\XBMC\userdata
00:38:58 T:2492 M:4294967295 NOTICE: loading special://masterprofile/guisettings.xml
00:38:58 T:2492 M:4294967295 NOTICE: Getting hardware information now...
00:38:58 T:2492 M:4294967295 NOTICE: Checking resolution 10
00:38:58 T:2492 M:4294967295 NOTICE: Setting autoresolution mode 12
00:38:58 T:2492 M:4294967295 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
00:38:58 T:2492 M:4294967295 NOTICE: ExternalPlayer Filename: C:\Program Files (x86)\Windows Media Player\wmplayer.exe
00:38:58 T:2492 M:4294967295 NOTICE: ExternalPlayer Tweaks: Forceontop (false), Hideconsole (false), Hidecursor (false), Hidexbmc (false), StartupTime (5000)
00:38:58 T:2492 M:4294967295 NOTICE: Default DVD Player: dvdplayer
00:38:58 T:2492 M:4294967295 NOTICE: Default Video Player: externalplayer
00:38:58 T:2492 M:4294967295 NOTICE: Default Audio Player: paplayer
00:38:58 T:2492 M:4294967295 NOTICE: C:\Users\media\AppData\Roaming\XBMC\userdata\sources.xml
00:38:59 T:2492 M:4294967295 NOTICE: GL_VENDOR = ATI Technologies Inc.
00:38:59 T:2492 M:4294967295 NOTICE: GL_RENDERER = ATI Radeon HD 4800 Series
00:38:59 T:2492 M:4294967295 NOTICE: GL_VERSION = 2.1.8664
00:38:59 T:2492 M:4294967295 NOTICE: GL_EXTENSIONS = GL_AMDX_vertex_shader_tessellator GL_AMD_performance_monitor
etc....
00:38:59 T:2492 M:4294967295 NOTICE: start dvd mediatype detection
00:38:59 T:2492 M:4294967295 NOTICE: initializing playlistplayer
00:38:59 T:2492 M:4294967295 NOTICE: DONE initializing playlistplayer
00:38:59 T:2492 M:4294967295 NOTICE: load default skin:[PM3.HD]
00:38:59 T:2492 M:4294967295 NOTICE: initialize done
00:38:59 T:2492 M:4294967295 NOTICE: Running the application...
00:38:59 T:2492 M:4294967295 NOTICE: ES: Starting event server
00:38:59 T:4476 M:4294967295 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
00:38:59 T:4476 M:4294967295 NOTICE: UDP: Listening on port 9777
00:38:59 T:4420 M:4294967295 NOTICE: AudioScrobbler: Handshake successful.
00:39:21 T:2492 M:4294967295 NOTICE: DVDPlayer: Opening: M:\My Media\My Movies\LOST WORLD\LOSTWORLD169.iso
00:39:21 T:2492 M:4294967295 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
00:39:21 T:2972 M:4294967295 NOTICE: Creating InputStream
00:39:21 T:2972 M:4294967295 WARNING: WARNING: File is larger than 32bit stat can handle, file size will be reported as 0 bytes
00:39:21 T:2972 M:4294967295 NOTICE: DVDPlayer: playing a dvd with menu's
00:39:21 T:2972 M:4294967295 NOTICE: Creating Demuxer
00:39:21 T:2972 M:4294967295 NOTICE: Opening audio stream: 0 source: 512
00:39:21 T:2972 M:4294967295 NOTICE: Opening audio stream: 1 source: 512
00:39:21 T:2972 M:4294967295 NOTICE: Opening Subtitle stream: 0 source: 512
00:39:21 T:2972 M:4294967295 NOTICE: Opening Subtitle stream: 1 source: 512
00:39:21 T:2972 M:4294967295 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
00:39:21 T:2972 M:4294967295 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
00:39:21 T:2972 M:4294967295 NOTICE: Opening audio stream: 1 source: 256
00:39:21 T:2972 M:4294967295 NOTICE: Finding audio codec for: 86019
00:39:21 T:2972 M:4294967295 NOTICE: Creating audio thread
00:39:21 T:548 M:4294967295 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
00:39:21 T:548 M:4294967295 NOTICE: Creating audio device with codec id: 86019, channels: 2, sample rate: 48000, pass-through
00:39:21 T:2972 M:4294967295 NOTICE: Opening video stream: 0 source: 256
00:39:21 T:2972 M:4294967295 NOTICE: Creating video codec with codec id: 2
00:39:21 T:2972 M:4294967295 NOTICE: Creating video thread
00:39:21 T:4988 M:4294967295 NOTICE: running thread: video_thread
00:39:21 T:4988 M:4294967295 NOTICE: fps: 25.000000, pwidth: 720, pheight: 480, dwidth: 853, dheight: 480
00:39:21 T:4988 M:4294967295 NOTICE: Display resolution ADJUST : 1920x1080 @ 59.94Hz (80)
00:39:21 T:4988 M:4294967295 WARNING: Upscale: selected algorithm 1
00:39:21 T:548 M:4294967295 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
00:39:22 T:2492 M:4294967295 NOTICE: Using GL_TEXTURE_2D
00:39:22 T:2492 M:4294967295 NOTICE: GL: Selecting YUV 2 RGB Progressive Shader
00:39:22 T:2492 M:4294967295 NOTICE: GL: NPOT texture support detected
00:39:23 T:4988 M:4294967295 WARNING: CDVDMessageQueue(video)::Get - retrieved last data packet of queue
00:39:32 T:548 M:4294967295 WARNING: CDVDMessageQueue(audio)::Get - retrieved last data packet of queue
00:39:32 T:2972 M:4294967295 NOTICE: Opening Subtitle stream: 3 source: 256
00:39:32 T:2972 M:4294967295 WARNING: CDVDPlayer::CheckPlayerInit(3) - Ignoring too large delay of 4582600.000000
00:40:04 T:2492 M:4294967295 NOTICE: CDVDPlayer::CloseFile()
00:40:04 T:2492 M:4294967295 NOTICE: DVDPlayer: waiting for threads to exit
00:40:04 T:2972 M:4294967295 NOTICE: CDVDPlayer::OnExit()
00:40:04 T:2972 M:4294967295 NOTICE: DVDPlayer: closing audio stream
00:40:04 T:2972 M:4294967295 NOTICE: Closing audio stream
00:40:04 T:2972 M:4294967295 NOTICE: Waiting for audio thread to exit
00:40:04 T:548 M:4294967295 ERROR: CDVDAudio::AddPackets - failed to add leftover bytes to render
00:40:04 T:548 M:4294967295 NOTICE: thread end: CDVDPlayerAudio::OnExit()
Turn on vsync.
