Full Version: What version of XBMC works best with Auriga?
Also, I've noticed, with BABYLON v9.04 and the most recent build of Auriga 2 problems. 1: sometimes when you press "C" on a movie, it doesn't bring up the right menu and can take many times to actually get the right menu up. 2: The menu to change the background artwork and covert art only shows "watch" & "trailer" instead of the normal options. I'm not sure if this is a problem that is related to the version of XBMC I'm using so I'll wait to see what happens if I change it to the ideal version once I know what to use.
Edit: On the second problem, it seems its a part of the newer kiosk mode, so got that working.
9.04 is very old... use a newer build. 'Search' is your friend.
That's the version the stickied guide has.
sentinel41 Wrote:That's the version the stickied guide has.
thats to go with Aeon stark
If you want the best from Aeon Aruiga then you will need the latest svn release of xbmc try here. You need to remember Aeon Aruiga is still in development
http://danielpatton.com/user-accounts/XB...tes/ikons/
or
http://www.sshcs.com/xbmc/
Thanks for the straightforward answer zig, I appreciate it.
If you use Windows, stay with 9.04 and use the XBMC Updater. For Linux & OSX use the builds from sshcs.
