Full Version: Coding the Context Menu?
What is the trick to have the context menu display right? My problem is that whatever I do, the top, middle and bottom texture never become one panel. The bottom texture doesnt seem to react on posy and the whole control just behaves weirdly.
I even tried to use DialogContextMenu.xml from PM3HD together with its textures and I still get the same results with top and bottom texture not being aligned with middle texture.
Before asking I tried to find something in the forums and manual with no luck. Any advice is highly appreciated.Thanks
Never mind, I solved it. The weirdness was caused by image control aligny element in Defaults.xml.
