2009-06-17, 18:10
AppleTV 2.3.1
XBMC SVN R21101
Manual Install from: Google "XBMC nightly builds"
SVN Repo Installer v1.7.6
From a few XBMC SVN revs back, I have been experiencing an issue of XBMC hanging after the following:
Run SVN Installer Repo, select Updates, select an update plugin, Install, and all goes well ending with an OK, bringing me back to the list. Select another Update, Install, and XBMC freezes, if I have logging enabled, it shows no movement in any field. On restart of XBMC, The selected plugin is indeed installed and seems to work properly.
This occurs with add-on as well with consecutive installs.
xbmc.log @ http://pastebin.ca/1463584
XBMC SVN R21101
