Full Version: Web Remote Control for TouchScreen?
Hello,
I finaly decide to finish my htpc and choose a DH 102 with a 7'' Touch screen.
The problem is that i don't like the software given with Smile
After a lots of search i didn't find the software to control the xbmc from the touch screen (no way to use clone mode since i use Aeon and FullHD.)
Does anyone know a software that can do that ( I only need a current play and music gestion with the tv off) ?
In the same time i started a test proggy based on the idea of HTTP-R to have something that suit my need (800*600 or 1024 now playing full music control, beautifull full ajax and touch compliant Smile ).
Would some people interrested in such project ? Smile and is there a web designer with time aroud there Smile Smile
Tolriq.
You might want to try XBMControl Web at
http://code.google.com/p/xbmcontrol-web/
It is still a work in progress but it may fill most of your needs.
The concept is here, but the interface is definitively not touch screen compliant Sad
Forum topics tagged "touchscreen":
http://forum.xbmc.org/tags.php?tag=touchscreen
For HTTP Kabooga's XBMControl would proably be a good base, discussion here:
http://forum.xbmc.org/showthread.php?tid=51596
Also checkout:
http://forum.xbmc.org/showthread.php?tid=18680
and:
http://wiki.xbmc.org/?title=HTTPAPI
Happy coding! Wink
Thanks Smile
Coding as already started Smile Php 5 + Mootools + Http API since i may want to control from lan and not only reading the database with sqlite Smile
The idea is here and based on what i use to code usually so template multi language, Now playing is working, the little remote control also and dabase interrogation for browsing and getting thumbs works too Smile
Only need time now :p
And someone to make the html/css part since i'm really not good at this Sad
I'm not going to start a new thread sp i ask the question here Smile
I received my case and there's a little problem that i didn't test before Smile
When XBMC is launched full screen on the main display it blackout the second display Sad So it render my touchscreen more or less useless Sad
Any one already seen that in dual screen ? is there an easy way to correct that (no clone option possible)
