Full Version: tvshowmatching tag
I am having trouble with this. I have searched the forums but can't find an answer. I created a file called "advancedsettings.xml" and put it in my "c:\program files (x86)\xbmc\userdata" directory. This is what I have in it:
Quote:<advancedsettings>
<tvshowmatching>
<regexp>Season[\._ ]([0-9]+)[\\/]([0-9]+)[^\\/]*</regexp>
</tvshowmatching>
</advancedsettings>
My files are formatted as: TV show name\Season 1\01 episode name.avi
It is picking up the TV show titles in xbmc but they all contain 0 episodes.
If I remember correctly, it should be in the application data folder:
\user\<your user name>\appdata\roaming\xbmc\userdata (I'm going by memory on that location, but it's very similar to that). You may need to enable "view hidden files and folders" to find it.
That's it. Thanks a lot.
robothunter Wrote:That's it. Thanks a lot.
You're welcome. Glad I could help!
