I'm desparately trying to have my creative audigy 2 zs pci sound card working. I'm on Ubuntu 9.04. I have sound on Rhythmbox, Totem, and VLC. Strangely enough, I also have the navigation sounds of XBMC. But no sound for movies or music. I'm also trying to stay away from the too complicated Pulseaudio, so I am working with alsa. Any idea what I could try?
You should post what your current settings are for audio hardware in XBMC as well as what kind of connection to your sound setup you're using (i.e.: 6 channel analog). I would recommend posting your aplay -l and aplay -L for others to see and diagnose. Also, if you're using a .asoundrc file in your home directory, post that as well.
aplay -l: (sorry, its in french)
Quote:pierre@pierre-desktop:~$ aplay -l
**** Liste des PLAYBACK périphériques ****
carte 0: Audigy2 [Audigy 2 ZS [SB0350]], périphérique 0 : emu10k1 [ADC Capture/Standard PCM Playback]
Sous-périphériques: 32/32
Sous-périphérique: #0: subdevice #0
Sous-périphérique: #1: subdevice #1
Sous-périphérique: #2: subdevice #2
Sous-périphérique: #3: subdevice #3
Sous-périphérique: #4: subdevice #4
Sous-périphérique: #5: subdevice #5
Sous-périphérique: #6: subdevice #6
Sous-périphérique: #7: subdevice #7
Sous-périphérique: #8: subdevice #8
Sous-périphérique: #9: subdevice #9
Sous-périphérique: #10: subdevice #10
Sous-périphérique: #11: subdevice #11
Sous-périphérique: #12: subdevice #12
Sous-périphérique: #13: subdevice #13
Sous-périphérique: #14: subdevice #14
Sous-périphérique: #15: subdevice #15
Sous-périphérique: #16: subdevice #16
Sous-périphérique: #17: subdevice #17
Sous-périphérique: #18: subdevice #18
Sous-périphérique: #19: subdevice #19
Sous-périphérique: #20: subdevice #20
Sous-périphérique: #21: subdevice #21
Sous-périphérique: #22: subdevice #22
Sous-périphérique: #23: subdevice #23
Sous-périphérique: #24: subdevice #24
Sous-périphérique: #25: subdevice #25
Sous-périphérique: #26: subdevice #26
Sous-périphérique: #27: subdevice #27
Sous-périphérique: #28: subdevice #28
Sous-périphérique: #29: subdevice #29
Sous-périphérique: #30: subdevice #30
Sous-périphérique: #31: subdevice #31
carte 0: Audigy2 [Audigy 2 ZS [SB0350]], périphérique 2 : emu10k1 efx [Multichannel Capture/PT Playback]
Sous-périphériques: 8/8
carte 0: Audigy2 [Audigy 2 ZS [SB0350]], périphérique 3 : emu10k1 [Multichannel Playback]
Sous-périphériques: 1/1
carte 0: Audigy2 [Audigy 2 ZS [SB0350]], périphérique 4 : p16v [p16v]
carte 1: Intel [HDA Intel], périphérique 0 : ALC662 Analog [ALC662 Analog]
carte 1: Intel [HDA Intel], périphérique 1 : ALC662 Digital [ALC662 Digital]
aplay -L
Quote:pierre@pierre-desktop:~$ aplay -L
front:CARD=Audigy2,DEV=0
Audigy 2 ZS [SB0350], ADC Capture/Standard PCM Playback
Front speakers
rear:CARD=Audigy2,DEV=0
Rear speakers
center_lfe:CARD=Audigy2,DEV=0
Center and Subwoofer speakers
side:CARD=Audigy2,DEV=0
Side speakers
surround40:CARD=Audigy2,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Audigy2,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audigy2,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audigy2,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audigy2,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audigy2,DEV=0
IEC958 (S/PDIF) Digital Audio Output
null
Discard all samples (playback) or generate zero samples (capture)
front:CARD=Intel,DEV=0
HDA Intel, ALC662 Analog
Front speakers
surround40:CARD=Intel,DEV=0
surround41:CARD=Intel,DEV=0
surround50:CARD=Intel,DEV=0
surround51:CARD=Intel,DEV=0
surround71:CARD=Intel,DEV=0
iec958:CARD=Intel,DEV=0
HDA Intel, ALC662 Digital
I'm using the regular green connection for one set of speakers. And I have no .asoundrc file.
Are you connected the card via passthrough or analog output?
rossgemuend Wrote:You should post what your current settings are for audio hardware in XBMC
we still need this!
my best guess at the moment would be that mplayer and paplayer send the audio to either the intel card or the SPDIF out of the audigy (fantastic card btw, I loved the emu10k1!)
Audio output: Analog
Audio output device: default
Again, I have the xbmc navigation sounds, and no sound playing movies or music.
If the player is sending the audio to the intel card. Would the solution be to disable the intel card in the Bios?
Eureka!
Disabling the integrated Intel card did it. Thanks for the hint.
