First I love the skin and am having a blast importing my Movie Library into it. I currently use a MCE remote that works great. However I cant for the life of me figure out how to exit the program. I know, noobitis.....lol
thanks
Go to Settings --> Customize --> Shortcuts
Then push left or right until you see "Shutdown". It will be dark. Then press Enter.
Now it will show on the main menu.
Alternatively, you can press 'S' if you don't want it listed on the main menu. 'S' will bring up a menu with various options with shutdown at the bottom.
mach170 Wrote:Go to Settings --> Customize --> Shortcuts
Thanks for the quick reply...
