i been reading on the forum cant seem to find a way to lower the poster in showcase view. the only info about shrinking the poster size is for the new aeon skin which i dont like much since i cant add my own menu tab like on the horizonz. any help would be appreciated. thanks
lxr109 Wrote:i been reading on the forum cant seem to find a way to lower the poster in showcase view. the only info about shrinking the poster size is for the new aeon skin which i dont like much since i cant add my own menu tab like on the horizonz. any help would be appreciated. thanks
Depending on what you want i've got maybe the solution:
edit: FullscreenViews.xml (in folder 720p)
go to the line: <include name="Viewtype_Showcase"> under that you can find:
<posy>280</posy>
Changing the number to another value will move up or down your showcase.
Good luck!
