2009-06-22, 22:54
I'm no dummy with XBMC, but this one has me stumped. This has never worked for me in any of the versions of XBMC I've had.
My naming convention is "Show\101 - Pilot.avi" since I don't see the point in separating by seasons since the library does that anyway.
The show I am having issues with is "The 4400". It recognizes the show, and I'm using thetvdb.com as a scraper, which DOES have the episode info, but it refuses to scan the episodes. Nearest I can figure is it thinks "The 4400" is "The 44", episode "00", but I cant be sure. An example episode is "401 - The Wrath of Graham.avi"
Here is my tvshowmatching tag:
The xbmc.log file contains the following, which i generated by deleting the log file and rebooting, then manually refreshing the show:
<tvshowmatching>
<regexp>([0-9]+)([0-9][0-9])[^\\/]*</regexp>
<regexp>([0-9]+)x([0-9]+)[^\\/]*</regexp>
<regexp>s([0-9]+)e([0-9]+)[^\\/]*</regexp>
</tvshowmatching>
13:42:42 M: 57303040 NOTICE: -----------------------------------------------------------------------
13:42:42 M: 57282560 NOTICE: Starting XBMC, Platform: Xbox. Built on May 21 2009 (SVN:20439, compiler 1310)
13:42:42 M: 57282560 NOTICE: special://xbmc/ is mapped to: Q:\
13:42:42 M: 57282560 NOTICE: special://masterprofile/ is mapped to: q:\UserData
13:42:42 M: 57282560 NOTICE: special://home/ is mapped to: Q:\
13:42:42 M: 57282560 NOTICE: special://temp/ is mapped to: Z:\
13:42:42 M: 57282560 NOTICE: The executable running is: E:\dash\default.xbe
13:42:42 M: 57282560 NOTICE: Log File is located: Q:\xbmc.log
13:42:42 M: 57282560 NOTICE: -----------------------------------------------------------------------
13:42:42 M: 57282560 NOTICE: Unmapped drive T
13:42:42 M: 57282560 NOTICE: Mapping drive T to Harddisk0\Partition1\dash\UserData
13:42:42 M: 57282560 NOTICE: Setup DirectX
13:42:42 M: 57257984 NOTICE: Mapping drive C to Harddisk0\Partition2
13:42:42 M: 57253888 NOTICE: Mapping drive E to Harddisk0\Partition1
13:42:42 M: 57253888 NOTICE: Unmapped drive D
13:42:42 M: 57253888 NOTICE: Mapping drive D to Cdrom0
13:42:46 M: 57253888 NOTICE: Mapping drive F to Harddisk0\Partition6
13:42:46 M: 57253888 NOTICE: Mapping drive X to Harddisk0\Partition3
13:42:46 M: 57253888 NOTICE: Mapping drive Y to Harddisk0\Partition4
13:42:46 M: 57253888 NOTICE: Unmapped drive Z
13:42:46 M: 57253888 NOTICE: Mapping drive Z to Harddisk0\Partition5
13:42:46 M: 57253888 NOTICE: load settings...
13:42:46 M: 57253888 NOTICE: Mapping drive P to Harddisk0\Partition1\dash\UserData
13:42:46 M: 57253888 NOTICE: special://profile/ is mapped to: q:\UserData
13:42:46 M: 57253888 NOTICE: loading special://masterprofile/guisettings.xml
13:42:46 M: 57077760 NOTICE: Getting hardware information now...
13:42:46 M: 57077760 NOTICE: Checking resolution 10
13:42:46 M: 57077760 NOTICE: Setting autoresolution mode 0
13:42:46 M: 57077760 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
13:42:46 M: 57077760 NOTICE: Default Video Player: mplayer
13:42:46 M: 57077760 NOTICE: Default Audio Player: paplayer
13:42:46 M: 57077760 NOTICE: Per AV pack settings are off
13:42:46 M: 57204736 NOTICE: q:\UserData\sources.xml
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button browser_home
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button browser_favorites
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button browser_refresh
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button browser_search
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button launch_app1_pc_icon
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button launch_media_select
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button play_pause
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button stop
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button volume_up
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button volume_mute
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button volume_down
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button next_track
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button prev_track
13:42:46 M: 33476608 ERROR: Keyboard Translator: Can't find button launch_mail
13:42:46 M: 33738752 NOTICE: Network: Using dashboard IP settings
13:42:46 M: 33406976 NOTICE: Checking the Date!
13:42:47 M: 33406976 NOTICE: start dvd mediatype detection
13:42:47 M: 33341440 NOTICE: initializing playlistplayer
13:42:47 M: 33341440 NOTICE: DONE initializing playlistplayer
13:42:47 M: 33341440 NOTICE: start fancontroller
13:42:47 M: 32808960 NOTICE: load default skin:[PM3.HD]
13:42:48 M: 28311552 NOTICE: Updating video library on startup
13:42:48 M: 28303360 ERROR: Control 402 in window 10133 has been asked to focus, but it can't
13:42:48 M: 27750400 NOTICE: initialize done
13:42:48 M: 27713536 NOTICE: Running the application...
13:42:49 M: 27451392 NOTICE: start timeserver client
13:42:49 M: 27381760 NOTICE: XBFileZilla: Starting...
13:42:49 M: 27381760 NOTICE: XBFileZilla: 'FileZilla Server.xml' is missing or is corrupt!
13:42:49 M: 27381760 NOTICE: XBFileZilla: Starting ftp emergency recovery mode
13:42:49 M: 26656768 NOTICE: XBFileZilla: Started
13:42:49 M: 26656768 NOTICE: ES: Starting event server
13:42:49 M: 26132480 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:42:49 M: 21090304 NOTICE: UDP: Listening on port 9777
13:42:51 M: 21172224 WARNING: CUtil::GetMatchingSource... no matching source found for [Video plugins]
13:43:19 M: 17432576 ERROR: PCRE: Match limit reached
13:43:21 M: 17645568 ERROR: PCRE: Match limit reached
13:43:56 M: 19083264 NOTICE: My Videos: Scanning for video info using worker thread, operation took 01:08
13:44:14 M: 17010688 ERROR: PCRE: Match limit reached
13:44:15 M: 17010688 ERROR: PCRE: Match limit reached
