Full Version: [MOD] Recently Added Movies, TV Shows, and Music on the Home Screen
Pages: 1 2 3 4
1st a big thanks to Nuka1195 for the scriptNod
***UPDATE***
use andyblac newer recently added mod, what you can find here:
http://forum.xbmc.org/showpost.php?p=359...stcount=34
------------------------------------------ old ------------------------------------------------------------
this mod works just like the Weather on the home page works when you are on movies/tv shows it will popup and show you the last 4 movies/tv shows you added...
You will need to download 2 new files for this mod
(download http://www.mediafire.com/?mm3mjzylo5z)
then add them to your aeon skin folder
Includes_latest_added.xml in to your 720p folder
latest_added.py in to a new folder named extras
then open up home.xml and edit line 2 to say
<defaultcontrol always="true">[b]500[/b]</defaultcontrol>
then find <include>Furniture_HomeRSS</include> in home.xml and add this code just below it
<include>latest_added</include>
then open Includes.xml and add this line
<include file="Includes_latest_added.xml" />
and thats it....
how does this mod work? does it fade off after a couple of minutes? Does it scroll thru if you add several movies? etc.. can you post a video of this working as this is awesome!!!
Looks great.
I just noticed this in the developer forum...this helps alot because I know what I added others in the house always ask me.
Nice job
rflores2323 Wrote:how does this mod work? does it fade off after a couple of minutes? Does it scroll thru if you add several movies? etc.. can you post a video of this working as this is awesome!!!
it works just like the Weather on the home page works when you are on movies/tv shows it will popup and show the last 4 movies/tv shows added...
Could do with a bit more space between them but other than that looks a great addition.
WOW!
I Turn my back for 1 hour and it's finished?!?! Jees!!!! ;-) That's cool man! I will try this out tonight.
Wow. With all these mods it's hard to keep up Sometimes. So many great idea's.
Slightly Off Topic...
A few days ago I saw a thread where some of you where proposing to incorporate all these mod's. Did something come out of that?
Hitcher Wrote:Could do with a bit more space between them but other than that looks a great addition.
Second that.
An option to turn off the cover art would be good, it takes up a bit too much of the screen for my personal preference.
yep, i did not put that much time in to it as i was hoping that some one will add it there moded skin and make it look better Wink
Batemann Wrote:Second that.
zag2me Wrote:An option to turn off the cover art would be good, it takes up a bit too much of the screen for my personal preference.
all the code you need to edit is in Includes_latest_added.xml have a play...
looks great, just added it in myself
Line 51 needs changing to
<height>50</height>
Are we supposed to be able to play them from the Home menu now?
Hitcher Wrote:Are we supposed to be able to play them from the Home menu now?
you can but i did not add it as aeon uses up/down/left/right on the home menu..
what i was thinking of doing was adding a link for the submenu to move to the latest Movies/Tv shows list
some thing like this
<item>
   <description>Recently Added</description>
   <label>Recently added</label>
   <onclick>SetFocus(510)</onclick>
</item>
Ah right. And then there's the fact that Up/Down also moves the menu bar.
Pages: 1 2 3 4
