skunkm0nkee Wrote:Nope, not a XBMC limitation, just lazy programming on my part! I'll look into it for the next release.
Any word as to when the next release will be? Just thought Id ask as Id like to test this skin out as Waffa has mentioned how great this skin is and Ive been waiting for the next release.
Thnx!
that looks sweet...I was thinking of doing a fresh new xbmc install and re-install the skins as I have been playing with xbmc for so long now that i wouldnt mind fixing a lot of my mistakes
You can better rename/delete guisettings.xml (userdata). That will fix your mistakes.
xbmc and skins settings are default again and still have your skins and library.
New build and re-install skins is pointless if you're going to use your old userdata.
If you messe something up, it's your userdata !
Waffa Wrote:You can better rename/delete guisettings.xml (userdata). That will fix your mistakes.
I was thinking of re-vamping my libraries and file structures as well so I thought it couldnt hurt to do a full re-install and see how xbmc works after such.
I appreciate your reply and for providing me information that I was unaware of.
Hopefully a new release for MiniMeedia will be out soon, as I would love to configure and test this skin out
It should be out in the next few days. I had plans for what I wanted to include in the release but I just can't find the time these days to get any of it done.
To save any further delays I'm going to release the skin, as is, and also get it into the XBMC Skinning project SVN.
I just don't seem to be able to make the time for any skinning at the moment and with what is due to be coming up it's unlikely to change any time soon.
Once this release is out I'll aim to come back and fix any bugs but it's unlikely I'll be adding any new features in the near future.
skunkm0nkee Wrote:It should be out in the next few days. I had plans for what I wanted to include in the release but I just can't find the time these days to get any of it done.
Thanks for the update and Im sure we're all looking forward to the latest version of this skin.
just two bug reports from me:
1) FF & Rewind icons overlaps navigation bar
http://img232.imageshack.us/i/mmff.jpg/
2) when OSD menu slides in or out when playing a video, you can see for a while movie/episode synopsis text overlapping navigation buttons. I've tried to capture it, but without success, it's very brief, yet annoying
Having just updated to the latest MiniMeedia my home page now doesn't display any backdrops? The backdrops display fine under Weather / TV Shows / Movies / etc, it's just the home screen that's black. I've tried just about everything I can think of, "Hide Weather Fanart" is turned off etc, am I doing something wrong?
Other than that, I've been using MiniMeedia for a while now and I think it's awesome! Definitely my favourite skin. The only thing I slightly miss, I think possibly from the Hitcher skin, is how easy it was to play movie trailers and TV episode previews - you'd press "down" from the movie/episode info screen. It's hardly much more difficult now, it's only a couple of clicks from "Refresh" to "Trailer", but maybe you could make the info screen default onto "Trailer" instead of "Refresh"?
Thanks for all the hardwork and to anyone that can help sort my problem.
EDIT: Thought I'd add that I'm running XBMC 9.04.1 r20672 and MiniMeedia v0.92
EDIT2: Updating to the latest svn version solved the problem.
You should update xbmc to a recent svn version if you want to see the backdrops on these new skins.
Did you set the background folder for home?
Updating to the latest svn version has solved the problem, thanks.
