Full Version: System setting doesn't work
I am completely new to XBMC. I run it on an old laptop under WinXP. The default skin works nicely. I do like MediaStream better, though. There is only one issue: When I run MediaStream, I cannot enter the system settings in the main menue. I left click and all the other options go blank for a second but then nothing happens. All the other options (video, music etc.) work fine.
Does anybody have a clue what the issue might be?
Greetings!
Mediastream is not meant for the mouse. Use a keyboard or remote control or you may have issues with things like this at other times.
Does it go to system settings when you use the keyboard?
Basically any skin but the default PM3.HD has issues with the mouse (they just arn't designed for it) so best learn to use a remote or keyboard
you are right. It does work with the keyboard and not with the mouse. Thanks for your input. Maybe I buy a remote one day. Till then I will stick to other skins. MayhemIII works fine with just a mouse.
Cheers,
B
