Full Version: Help with movie art...
I've nearly got my XBMC box up and running but having some problems with the thumbnail/fanart on Aeon.
My movies show nothing for artwork, thumbnail or otherwise.
When I pull up more information on a given movie it shows all the information such as date, actors, movie info, etc, but no art. When I select "thumbnail" from the movie information page I get about three options all of which are blank, so I try the "browse" and pick one I've saved locally, no good. I've tried naming the thumbnail the same as the movie file with a .jpg, .tbn, etc, but no good, I've even tried putting it into a folder and using "folder.jpg" but still no thumbnails or art shows up for the movie. Just the default movie icon.
Anyone else have this problem?
Specs:
-AMD Phenom II x4 2.8ghz
-8192mb of DDR2
-ATI 3450 256mb PCI-e using HDMI out to Pioneer 50" Plasma
-2x 1tb drives
-1x DVDRW
-Windows Server 2003 x64
Using the Windows 9.04 repack version of XBMC and I will have to check the version of Aeon (just downloaded it from Git the other day).
Are you using MIP or Ember to organize you media?
Is your folder structure like this?
I'm not familiar with those apps.
I was just putting movie1.avi and movie1.tbn into movie1 directory.
That did the trick, thanks guys!
