2009-07-14, 19:33
2009-07-14, 19:46
I only tried for the first time last night w/ a new library.
2009-07-14, 19:51
I did use my old library with the test and it is running fine ones extracted in PM3 HD.
But the xbox doesn't run as smooth as without the patch. (In MiniMeedia)
Extracting the flags is heavy for the xbox.
Hope that what spiff suggested works !!!
2009-07-14, 20:44
Even after extracting free memory is lower in the patched build.
2009-07-15, 08:49
I've made some improvements in the patch, mainly some missing stuff from linuxport + the thread thing spiff mentioned.... You can get it at http://rocky.eld.leidenuniv.nl/hd_flagging_new.patch . Note that you MUST apply it to a clean copy of the current SVN-head....
2009-07-15, 14:48
arnova Wrote:I've made some improvements in the patch, mainly some missing stuff from linuxport + the thread thing spiff mentioned.... You can get it at http://rocky.eld.leidenuniv.nl/hd_flagging_new.patch . Note that you MUST apply it to a clean copy of the current SVN-head....
arnova,
do u think this will ever go into the main xbmc for xbox? I have no idea how to compile my own as I dont have access to the tools needed.
2009-07-15, 18:08
I'd also like to test this out if it gets added to main XBMC for Xbox
2009-07-15, 19:02
jarod71 Wrote:arnova,
Not sure yet. At least not for now until we're certain it works properly (including the db issues). For now I have created a seperate xbox-test branch people can build from. It also includes the code for autothumbs on Xbox as the backend is pretty much the same as the HD flagging stuff.
The repository is located at:
https://xbmc.svn.sourceforge.net/svnroot.../xbox-test
We could ask the Quester to provide (additional) builds for it so people can test it.
2009-07-15, 19:59
Nice like it test branch
Did have a go with the second patch but doesn't extract the flags.
2009-07-15, 20:11
Im not sure but mine isn't showing the flgas either but i ear the disk like when it was extrating.
I did a fresh install as it didn't recognized the library i scanned yesterday.
2009-07-15, 20:21
Have a hard mod with led indicators.
Those blink when xbox loading/extracting/etc...
Those led's are damn handy (especially with heavy skins), can see what the xbox is doing.
And he's doing nothing in movies.
2009-07-15, 22:42
Waffa Wrote:Have a hard mod with led indicators.
so the current patch is not working then?
2009-07-16, 11:51
I think you need to enable it explicitly in the video settings menu now, since I forgot to merge that part in the previous patch....
2009-07-16, 12:03
Settings was not there.
There's already a new build from new xbox test branch.
Didn't test it, maybe tonight, have a lot to do today.
2009-07-16, 16:28
arnova Wrote:I think you need to enable it explicitly in the video settings menu now, since I forgot to merge that part in the previous patch....
Yea, I looked for that for a while the first go around, I was thinking I was crazy
But the option is there now?
