Full Version: [LIVE on HDD] script trouble :( ...
Guys!
On 8.10 it works w/o problem, I went to 9.04 and has this:
23:31:18 T:2952788880 M:875474944 NOTICE: -->Python Interpreter Initialized<--
23:31:18 T:2952788880 M:875405312 DEBUG: Process - The source file to load is special://home/scripts/Common Scripts/DboxTVViewer/default.py
23:31:18 T:2952788880 M:875474944 DEBUG: Process - Setting the Python path to /home/xbmc/.xbmc/scripts/Common Scripts/DboxTVViewer;/usr/share/xbmc/system/python/python24.zip;/usr/share/xbmc/system/python/lib/python24.zip;/usr/share/xbmc/system/python/lib/python2.4/;/usr/share/xbmc/system/python/lib/python2.4/plat-linux2;/usr/share/xbmc/system/python/lib/python2.4/lib-tk;/usr/share/xbmc/system/python/lib/python2.4/lib-dynload
23:31:18 T:2952788880 M:875474944 DEBUG: Process - Entering source directory /home/xbmc/.xbmc/scripts/Common Scripts/DboxTVViewer
23:31:18 T:2952788880 M:874319872 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/strop.so. flags: 2
23:31:18 T:2952788880 M:874422272 DEBUG: Loading: /home/xbmc/.xbmc/temp/strop.so
23:31:18 T:2952788880 M:874422272 DEBUG: RegisterExtensionLib, adding strop.so (0xaf77b68)
23:31:18 T:2952788880 M:874422272 DEBUG: xbp_dlsym - load symbol initstrop
23:31:18 T:2952788880 M:874524672 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/_socket.so. flags: 2
23:31:18 T:2952788880 M:874450944 DEBUG: Loading: /home/xbmc/.xbmc/temp/_socket.so
23:31:18 T:2952788880 M:874450944 DEBUG: RegisterExtensionLib, adding _socket.so (0xae12ca0)
23:31:18 T:2952788880 M:874450944 DEBUG: xbp_dlsym - load symbol init_socket
23:31:18 T:2952788880 M:873893888 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/_ssl.so. flags: 2
23:31:18 T:2952788880 M:874098688 DEBUG: Loading: /home/xbmc/.xbmc/temp/_ssl.so
23:31:18 T:2952788880 M:874098688 DEBUG: RegisterExtensionLib, adding _ssl.so (0xae248e0)
23:31:18 T:2952788880 M:874098688 DEBUG: xbp_dlsym - load symbol init_ssl
23:31:18 T:2952788880 M:873902080 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/time.so. flags: 2
23:31:18 T:2952788880 M:874004480 DEBUG: Loading: /home/xbmc/.xbmc/temp/time.so
23:31:18 T:2952788880 M:874004480 DEBUG: RegisterExtensionLib, adding time.so (0xafada90)
23:31:18 T:2952788880 M:874004480 DEBUG: xbp_dlsym - load symbol inittime
23:31:19 T:2952788880 M:873500672 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/math.so. flags: 2
23:31:19 T:2952788880 M:873533440 DEBUG: Loading: /home/xbmc/.xbmc/temp/math.so
23:31:19 T:2952788880 M:873533440 DEBUG: RegisterExtensionLib, adding math.so (0xaf18010)
23:31:19 T:2952788880 M:873533440 DEBUG: xbp_dlsym - load symbol initmath
23:31:19 T:2952788880 M:873463808 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/binascii.so. flags: 2
23:31:19 T:2952788880 M:873463808 DEBUG: Loading: /home/xbmc/.xbmc/temp/binascii.so
23:31:19 T:2952788880 M:873463808 DEBUG: RegisterExtensionLib, adding binascii.so (0xadd7a98)
23:31:19 T:2952788880 M:873463808 DEBUG: xbp_dlsym - load symbol initbinascii
23:31:19 T:2952788880 M:873394176 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/_random.so. flags: 2
23:31:19 T:2952788880 M:873496576 DEBUG: Loading: /home/xbmc/.xbmc/temp/_random.so
23:31:19 T:2952788880 M:873496576 DEBUG: RegisterExtensionLib, adding _random.so (0xaf7c1f8)
23:31:19 T:2952788880 M:873496576 DEBUG: xbp_dlsym - load symbol init_random
23:31:19 T:2952788880 M:873496576 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/fcntl.so. flags: 2
23:31:19 T:2952788880 M:873496576 DEBUG: Loading: /home/xbmc/.xbmc/temp/fcntl.so
23:31:19 T:2952788880 M:873496576 DEBUG: RegisterExtensionLib, adding fcntl.so (0xadd38a0)
23:31:19 T:2952788880 M:873496576 DEBUG: xbp_dlsym - load symbol initfcntl
23:31:19 T:2952788880 M:873357312 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/cStringIO.so. flags: 2
23:31:19 T:2952788880 M:873459712 DEBUG: Loading: /home/xbmc/.xbmc/temp/cStringIO.so
23:31:19 T:2952788880 M:873459712 DEBUG: RegisterExtensionLib, adding cStringIO.so (0xaf39620)
23:31:19 T:2952788880 M:873459712 DEBUG: xbp_dlsym - load symbol initcStringIO
23:31:21 T:2952788880 M:873357312 NOTICE: Traceback (most recent call last):
23:31:21 T:2952788880 M:873357312 NOTICE: File "/home/xbmc/.xbmc/scripts/Common Scripts/DboxTVViewer/default.py", line 1423, in ?
23:31:21 T:2952788880 M:873357312 NOTICE: dbox = DboxTV()
23:31:21 T:2952788880 M:873357312 NOTICE: File "/home/xbmc/.xbmc/scripts/Common Scripts/DboxTVViewer/default.py", line 1178, in __init__
23:31:21 T:2952788880 M:873369600 NOTICE:
23:31:21 T:2952788880 M:873369600 NOTICE: check_dir = os.listdir(CHANNELS_DIR)
23:31:21 T:2952788880 M:873369600 NOTICE: OSError
23:31:21 T:2952788880 M:873369600 NOTICE: :
23:31:21 T:2952788880 M:873369600 NOTICE: [Errno 2] No such file or directory: '/home/xbmc/.xbmc/scripts/Common Scripts/DboxTVViewer\\Images\\Channels\\'
23:31:21 T:2952788880 M:873369600 ERROR: Scriptresult: Error
23:31:21 T:2952788880 M:873369600 INFO: Loading skin file: DialogOK.xml
23:31:22 T:2952788880 M:873369600 DEBUG: Load DialogOK.xml: 25.40ms
23:31:22 T:3050440592 M:873369600 DEBUG: ------------------- GUI_MSG_WINDOW_INIT
23:31:22 T:3050440592 M:873369600 DEBUG: Диалог OK
23:31:22 T:3050440592 M:873369600 DEBUG: Load button-focus2.png: 0.3ms (bundled)
23:31:22 T:3050440592 M:873369600 DEBUG: Alloc resources: 0.74ms (0.02 ms skin load, 0.17 ms preload)
23:31:22 T:3050440592 M:872325120 DEBUG: Load DialogBack.png: 21.0ms (bundled)
23:31:22 T:3050440592 M:870166528 DEBUG: Load DialogFront.png: 13.7ms (bundled)
23:31:22 T:3050440592 M:867033088 DEBUG: Load separator.png: 0.2ms (bundled)
23:31:25 T:3050440592 M:867049472 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
23:31:25 T:3050440592 M:867049472 DEBUG: OnKey: 61453 pressed, action is 7
23:31:25 T:3050440592 M:867049472 DEBUG: ------------------- GUI_MSG_WINDOW_DEINIT
23:31:25 T:3050440592 M:867049472 DEBUG: Диалог OK
23:31:26 T:2952788880 M:869244928 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/collections.so. flags: 2
23:31:26 T:2952788880 M:869208064 DEBUG: Loading: /home/xbmc/.xbmc/temp/collections.so
23:31:26 T:2952788880 M:869208064 DEBUG: RegisterExtensionLib, adding collections.so (0xaf11730)
23:31:26 T:2952788880 M:869208064 DEBUG: xbp_dlsym - load symbol initcollections
23:31:26 T:2952788880 M:869208064 INFO: Python script stopped
23:31:26 T:2952788880 M:869208064 DEBUG: Thread 2952788880 terminating
23:31:26 T:3050440592 M:869208064 DEBUG: python thread 1 destructed
23:31:26 T:3050440592 M:869208064 INFO: Python, unloading python24.dll because no scripts are running anymore
23:31:26 T:3050440592 M:869208064 DEBUG: UnloadExtensionLibs, clearing python extension libraries
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: strop.so
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: _socket.so
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: _ssl.so
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: time.so
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: math.so
23:31:26 T:3050440592 M:869208064 DEBUG: Unloading: binascii.so
23:31:26 T:3050440592 M:869277696 DEBUG: Unloading: _random.so
23:31:26 T:3050440592 M:869277696 DEBUG: Unloading: fcntl.so
23:31:26 T:3050440592 M:869277696 DEBUG: Unloading: cStringIO.so
23:31:26 T:3050440592 M:869277696 DEBUG: Unloading: collections.so
23:31:26 T:3050440592 M:869277696 DEBUG: Unloading: python24-i486-linux.so
PLS delete - i found solution
How about instead you share your solution with the community?
You should know by now to use a paste site for your log and NOT to snip it. Remember this in the future.
