Full Version: [REQUEST] Load playlist on start-up (like in PM3.HD)?
Can the "load playlist on start-up" feature make its way into Aeon and the associated mods?
Here's some related threads:
Auto Play Smart Playlist & Loop for infinity?
LastFM-stream on startup
music on startup
I'm not a coder at all, but I hope it's an easy task?
From startup.xml in PMIIIHD:
<window>
    <defaultcontrol always="true">10</defaultcontrol>
    <allowoverlay>no</allowoverlay>
    <controls>
        <control type="button" id="10">
            <description>trigger</description>
            <onfocus>ReplaceWindow(Home)</onfocus>
            <texturenofocus>-</texturenofocus>
            <texturefocus>-</texturefocus>
            <visible>!Skin.HasSetting(Use_Startup_Playlist)</visible>
        </control>
            <description>trigger with startup Playlist</description>
            <onfocus>XBMC.PlayMedia($INFO[Skin.String(Startup_Playlist_Path)])</onfocus>
            <visible>Skin.HasSetting(Use_Startup_Playlist)</visible>
        </control>
    </controls>
</window>
