Jezz_X,
Will this skin support media flagging on the xbox? I dont mean the native xbmc flagging but the workaround where we specify the flags in the videofile name? Like some of the other skins support?
Thanks for all the great work on this, you have a special talent at making all the bells and wistles run so smooth on xbox! I am still looking forward to your other skins in development...
jarod71 Wrote:Jezz_X,
Unlikely I'd have thought seeing as it was only a stopgap until native flagging got implemented into XBMC.
As for native flagging on the Xbox, you'll just have to wait and see I suppose but personally I don't see the point as nothing will be HD anyway.
Hitcher Wrote:I don't see the point as nothing will be HD anyway.
You're right, HD flags would be rare, but there are more type of video files that the xbox does support very well.
And don't forget the audio flags, no problem for the xbox.
I hope someone will do a mod to include the flagging support. it works great on other skins. I like it just for the studio flag and xvid, divx etc. I have had good success geting 720p xvid and now divx to work on xbox so yes the xbox can support HD.
apparently the native xbmc flagging slows down the xbox too much. the work around in other skins does not take much of a performance hit. not sure what is needed to incorporate it into this skin however. maybe someone else can comment on that?
Dear All,
is it possible to have the two box for the latest Movie / tv show in the main windows ordered top/bottom like in ver 0.8.8?
L.
lupick Wrote:Dear All, is it possible to have the two box for the latest Movie / tv show in the main windows ordered top/bottom like in ver 0.8.8? Thanks
L.
they went side-by-side when "now playing" appeared
i read jezz made that permanent just to make the coding a little simpler.
of course nothing stops your from changing it back yourself
or just go back to 0.8.8... i think thats what Jezz will say
big thanks for separating TV / Movies on home
( even though you dont like it ) Thanks Jezz_X
Id like this aswell. Can some one please upload 0.8.8 include file?
I looked through every option multiple times and cannot find an option anywhere. Can you get rid of the check mark for a watched movie?
SlaveUnit Wrote:I looked through every option multiple times and cannot find an option anywhere. Can you get rid of the check mark for a watched movie?
What do you want to show for watched movies?
nothing
I like to keep them without the "watched" flag.
Quickest (but not the best way) is to extract the Textures.xpr & delete overlaywatched.png & Repack.
buges Wrote:Quickest (but not the best way) is to extract the Textures.xpr & delete overlaywatched.png & Repack.
Or you could just d/l my mod. I just added the option in settings to hide the checkmark.
Jezz_X,
Any chance for this becoming an option in Settings > Skin > General ?
