Full Version: Need help with movie info`s
Hello all.
First off all, Wat a great piece of software is XBMC.
I have been trying it for a few days now on my newly builded htpc and i am very pleased with this soft, much much better then the hd software that came with my thermaltake htpc case.
But i can`t get 1 thing to work and that is that i can not get the movie info and pictures for my movies.
No info, no pictures, nothing.
I have scanned my movie folder but nothing happens, i have searched for a solution here on the forum but could not find a direct fix, there is so much posted Shocked
Oke i have the latest build from xbmc running.
I have it running on windows 7 build 7000 x64 ultimate.
I have the latest skins installed and have try`t several skins to see if it works on a other skin.
I have the options enabled to get the info from imdb.
Mabye something else needs to be installed ?? I hope someone can help me with this one , this option is very import end for me.
Thanks in advance.
Greats ysco.
From holland.
Never mind, i solved the problem and is fully working now.
Admin this thread can be deleted Wink
ysco..
Rather than deleting i suggest you describe in short how you solved it. In case someone googles for a similar problem.
