I have got xbmc setup Aeon and i am trying to setup multiplex but the info screen just isn't there when i install it. Can someone please direct me with right files and what i have to do with them.
the original AEON does not have multiplex
I suggest Dling a mod... I use AndyBlac's
Press up while in movies to bring up menu
I think it says "View: Showcase" as 1st option
Hit Enter
Select which view you want
Sounds liek you are in tv shows. You only get these 3 when you have not selected the option in settings to show all views.
No, you ONLY get Multiplex when you have not selected that option MrTourettes.
He's in file mode.... Multiplex is not available in file mode. Use search and wiki for learning about library-mode.
Thanks for all your help i got it working, and thank you to the XBMC team for such an excellent program and Aeon sexy skin
