Full Version: Background="true" coding?
So I am working towards moving my Operation mod to use the background="true" on the homepage and I am running into a snag....the images don't appear. First I just deleted my old coding and filled it in with the code in found in PM3.HD. All labels and positioning was fine, but I was not getting images. I also edited my custom_skinsettings.xml to match as well. Just to test I completely copied and pasted PM3.HD's home.xml and custom_skinsettings.xml into my Operation 720p folder and got the same results. I even am using the PM3.HD images and have the backgrounds folder in the skin folder. Below is my debug log and I can see there is a and error with the images loading, but I don't see why. If anyone can put a solution to it, I would greatly appreciate it. Thank!
Debug
Does this image:
special://skin/backgrounds/videosBig.jpg
exist?
Cheers,
Jonathan
No it doesn't.
well then its hardly suprizing its not loadign them since its looking for it according to the log
Quote:10:54:31 T:5696 M:851558400 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/musicBig.jpg Error: (2)
10:54:31 T:5696 M:851558400 ERROR: PICTURE: Error loading image special://skin/backgrounds/musicBig.jpg
10:54:32 T:1832 M:851312640 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 0
10:54:32 T:1832 M:851312640 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
10:54:32 T:5696 M:851308544 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/picturesBig.jpg Error: (2)
10:54:32 T:5696 M:851308544 ERROR: PICTURE: Error loading image special://skin/backgrounds/picturesBig.jpg
10:54:32 T:1832 M:851628032 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 0
10:54:32 T:1832 M:851628032 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
10:54:32 T:5696 M:851619840 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/weatherBig.jpg Error: (2)
10:54:32 T:5696 M:851615744 ERROR: PICTURE: Error loading image special://skin/backgrounds/weatherBig.jpg
10:54:33 T:1832 M:850534400 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 0
10:54:33 T:1832 M:850534400 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
10:54:33 T:5696 M:850530304 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/scriptsBig.jpg Error: (2)
10:54:33 T:5696 M:850530304 ERROR: PICTURE: Error loading image special://skin/backgrounds/scriptsBig.jpg
10:54:33 T:1832 M:850608128 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 0
10:54:33 T:1832 M:850608128 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
10:54:33 T:5696 M:850563072 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/settingsBig.jpg Error: (2)
10:54:33 T:5696 M:850558976 ERROR: PICTURE: Error loading image special://skin/backgrounds/settingsBig.jpg
10:54:33 T:1832 M:850477056 DEBUG: SDLKeyboard: scancode: 80, sym: 274, unicode: 0, modifier: 0
10:54:33 T:1832 M:850477056 DEBUG: CApplication::OnKey: 61480 pressed, action is 4
10:54:33 T:5696 M:850472960 DEBUG: msg: PICTURE::LoadImage: Unable to open image: special://skin/backgrounds/videosBig.jpg Error: (2)
10:54:33 T:5696 M:850472960 ERROR: PICTURE: Error loading image special://skin/backgrounds/videosBig.jpg
Sounds like you may be using a skin with version < 2.11
jmarshall Wrote:Sounds like you may be using a skin with version < 2.11
I first tried changing all the backdrops to have "Big" at the end, but it didn't work still. I then looked at the skin version and changed it from 2.1 to 2.11 and the images all show perfectly now.
Thanks for the help!!
Glad you got it working. In order to keep the signal to noise ratio up, the reason is because you're using ListItem.Icon to do this background stuff, and prior to version 2.11, this always appended Big to the filename.
As of version 2.11, ListItem.Icon just gives you the actual name - no more Big.
Cheers,
Jonathan
