Full Version: OpenGL problem with ATI HD2600 Catalyst 9.6 + XBMC_for_Windows-9.04.1-repack
Pages: 1 2
Hello all,
1. HP 8510p laptop
2. WinXP SP3, 32 bit,
3. Intel C2D T7500,
4. 2 GB,
5. ATI HD2600 Catalyst 9.6 + CCC,
8. XBMC_for_Windows-9.04.1-repack.exe installed
9. When I installed and tried to run XBMC i had received this error message:
Quote:"Windows default OpenGL driver detected. This driver is not supported. Please configure the OpenGL driver supplied by your video card vendor"
I tried to reintall the ATI driver but did not work. It seems that OpenGL is missing in my system. I thought it was installed during the Catalyst installation. If i run "SciTech GLDirect" OpenGL program (old) it start to load but the whole program run like in 2-bit coloring, not sharp pics at all.
I have an older laptop as well (Lenovo T60, XP SP2 32bit, 2GB RAM, ATI XT1300) an the same installation works.
Has someone faced against this problem before? I went through to forum and the wiki but did not find anything like this.
Any help is appreciated.
10. FULL Debug Log. I can not change the XBMC Settings - System because of the above-mentioned problem can not see any menus/submenus at all. sorry for that. I can post only the root log file:
20:50:56 T:1468 M:1425817600 NOTICE: -----------------------------------------------------------------------
20:50:56 T:1468 M:1425780736 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on May 26 2009 (SVN:20672, compiler 1500)
20:50:56 T:1468 M:1425780736 NOTICE: Intel® Core™2 Duo CPU T7500 @ 2.20GHz
20:50:56 T:1468 M:1425780736 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
20:50:56 T:1468 M:1425780736 NOTICE: special://xbmc/ is mapped to: E:\Program Files\XBMC
20:50:56 T:1468 M:1425780736 NOTICE: special://masterprofile/ is mapped to: E:\Program Files\XBMC\userdata
20:50:56 T:1468 M:1425780736 NOTICE: special://home/ is mapped to: E:\Program Files\XBMC
20:50:56 T:1468 M:1425772544 NOTICE: special://temp/ is mapped to: E:\Program Files\XBMC\cache
20:50:56 T:1468 M:1425776640 NOTICE: The executable running is: E:\Program Files\XBMC\XBMC.exe
20:50:56 T:1468 M:1425776640 NOTICE: Log File is located: E:\Program Files\XBMC\xbmc.log
20:50:56 T:1468 M:1425776640 NOTICE: -----------------------------------------------------------------------
20:50:56 T:1468 M:1425756160 NOTICE: Setup SDL
20:50:57 T:1468 M:1425022976 NOTICE: load settings...
20:50:57 T:1468 M:1424998400 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:50:57 T:1468 M:1424994304 NOTICE: loading special://masterprofile/guisettings.xml
20:50:57 T:1468 M:1424519168 NOTICE: Getting hardware information now...
20:50:57 T:1468 M:1424515072 NOTICE: Checking resolution 10
20:50:57 T:1468 M:1424510976 NOTICE: Setting autoresolution mode 1
20:50:57 T:1468 M:1424461824 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
20:50:57 T:1468 M:1424461824 NOTICE: Default DVD Player: dvdplayer
20:50:57 T:1468 M:1424461824 NOTICE: Default Video Player: dvdplayer
20:50:57 T:1468 M:1424457728 NOTICE: Default Audio Player: paplayer
20:50:57 T:1468 M:1424531456 NOTICE: special://masterprofile/sources.xml
20:50:57 T:1468 M:1424003072 NOTICE: GL_VENDOR = Microsoft Corporation
20:50:57 T:1468 M:1423998976 NOTICE: GL_RENDERER = GDI Generic
20:50:57 T:1468 M:1423998976 NOTICE: GL_VERSION = 1.1.0
20:50:57 T:1468 M:1423998976 NOTICE: GL_EXTENSIONS = GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
Are you trying to install the video card driver from the ATI website or from Windows update? Right now, the driver states it is using Microsoft's website.
Is there any chance you are using one of those patched installation files found in various places in the internets?
I am using the mobility modding tool too because ATI neither gateway offers drivers for the microsoft's running horse; windows XP . (only for some laptop videocard, not all, but mine is of the excluded part) [to note also that vista isnt running but crawling lol]
They only offers drivers for vista, whitch is almost racism to xp users HAHA Tongue
XBMc does the same for me. Wont run. I searched all around about opengl and ati, yet, i always thought that opengl came with windows as directx did.... Or that it came with the driver well anyway.. My ati card works well with all games and all the rest but not with xbmc....
Yet.. I belive that even my old pc whitch is nvidia based canot run xbmc anymore... Should verify that Tongue Seems that something went wrong at some time.... Or such.... Anyway, any help would do good Smile (even if i dont belive i will ever be able to run xbmc again...)
OpenGL does come with windows. It just doesn't at a high enough level.
Thanks the fest replies!
@natethomas, Matthieu: I downloaded the video driver from ATI website and modded with "Mobility Modding Tool" in order to get the official newest ATI drivers installed on my laptop. I have been using that tool for months and did not heave any problems with it.
1) If i copy all opengl.dll files system32 folder will it work?
2) Is it enough to get the MS opengl drivers to be able to run XBMC?
3) Where can i install?
I have tested XBMC on my older laptop and worked really well. That is the reason why i settled down to it, and now when i want to put it to a newer laptop, it does not work. It is a bit frustrating.
I managed to to activate the debug log:
This is the log if i use the default OpenGL:
Quote:12:37:32 T:1864 M:743026688 NOTICE: -----------------------------------------------------------------------
12:37:32 T:1864 M:742993920 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Jul 4 2009 (SVN:21397, compiler 1500)
12:37:32 T:1864 M:742993920 NOTICE: Intel® Core™2 Duo CPU T7500 @ 2.20GHz
12:37:32 T:1864 M:742989824 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
12:37:32 T:1864 M:742985728 NOTICE: Running with administrator rights
12:37:32 T:1864 M:742985728 NOTICE: special://xbmc/ is mapped to: E:\Program Files\XBMC
12:37:32 T:1864 M:742985728 NOTICE: special://masterprofile/ is mapped to: E:\Program Files\XBMC\userdata
12:37:32 T:1864 M:742985728 NOTICE: special://home/ is mapped to: E:\Program Files\XBMC
12:37:32 T:1864 M:742985728 NOTICE: special://temp/ is mapped to: E:\Program Files\XBMC\cache
12:37:32 T:1864 M:742985728 NOTICE: The executable running is: E:\Program Files\XBMC\XBMC.exe
12:37:32 T:1864 M:742985728 NOTICE: Log File is located: E:\Program Files\XBMC\xbmc.log
12:37:32 T:1864 M:742985728 NOTICE: -----------------------------------------------------------------------
12:37:32 T:1864 M:742961152 NOTICE: Setup SDL
12:37:33 T:1864 M:742178816 NOTICE: load settings...
12:37:33 T:1864 M:742150144 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:37:33 T:1864 M:742146048 NOTICE: loading special://masterprofile/guisettings.xml
12:37:33 T:1864 M:741642240 NOTICE: Enabled debug logging due to GUI setting
12:37:33 T:1864 M:741642240 NOTICE: Getting hardware information now...
12:37:33 T:1864 M:741642240 INFO: Using analog output
12:37:33 T:1864 M:741642240 INFO: AC3 pass through is enabled
12:37:33 T:1864 M:741642240 INFO: DTS pass through is enabled
12:37:33 T:1864 M:741642240 NOTICE: Checking resolution 10
12:37:33 T:1864 M:741642240 NOTICE: Setting autoresolution mode 1
12:37:33 T:1864 M:741634048 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:37:33 T:1864 M:741625856 NOTICE: Loaded playercorefactory configuration
12:37:33 T:1864 M:741625856 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:37:33 T:1864 M:741625856 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:37:33 T:1864 M:741621760 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
12:37:33 T:1864 M:741621760 NOTICE: Default DVD Player: dvdplayer
12:37:33 T:1864 M:741621760 NOTICE: Default Video Player: dvdplayer
12:37:33 T:1864 M:741621760 NOTICE: Default Audio Player: paplayer
12:37:33 T:1864 M:741818368 NOTICE: special://masterprofile/sources.xml
12:37:33 T:1864 M:741777408 DEBUG: Constructing surface 1280x720, shared=00000000, fullscreen=0
12:37:33 T:1864 M:741081088 NOTICE: GL_VENDOR = Microsoft Corporation
12:37:33 T:1864 M:741076992 NOTICE: GL_RENDERER = GDI Generic
12:37:33 T:1864 M:741076992 NOTICE: GL_VERSION = 1.1.0
12:37:33 T:1864 M:741072896 NOTICE: GL_EXTENSIONS = GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
12:37:33 T:1864 M:741072896 DEBUG: Asking to resize surface to 1280 x 720
12:37:33 T:1864 M:741068800 DEBUG: New size does not cover the screen
12:37:34 T:1864 M:740712448 INFO: GL: Maximum texture width: 1024
Hi, was searching for an answer to your problem and I came across this: http://glintercept.nutty.org/Ver0_5/
It's a opengl interceptor that can overwrite your gl version with one of your choice. It probably wont work, but I really wonder what would happen if you try it. P.S the program does overwrite the version for xbmc, I tried it.
and this is the error log if i run the 3rd party drivers (SciTech GLdirect) - Part 1
17:28:04 T:1484 M:1608646656 NOTICE: -----------------------------------------------------------------------
17:28:04 T:1484 M:1608613888 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Jul 4 2009 (SVN:21397, compiler 1500)
17:28:04 T:1484 M:1608605696 NOTICE: Intel® Core™2 Duo CPU T7500 @ 2.20GHz
17:28:04 T:1484 M:1608601600 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
17:28:04 T:1484 M:1608601600 NOTICE: Running with administrator rights
17:28:04 T:1484 M:1608601600 NOTICE: special://xbmc/ is mapped to: E:\Program Files\XBMC
17:28:04 T:1484 M:1608601600 NOTICE: special://masterprofile/ is mapped to: E:\Program Files\XBMC\userdata
17:28:04 T:1484 M:1608601600 NOTICE: special://home/ is mapped to: E:\Program Files\XBMC
17:28:04 T:1484 M:1608601600 NOTICE: special://temp/ is mapped to: E:\Program Files\XBMC\cache
17:28:04 T:1484 M:1608601600 NOTICE: The executable running is: E:\Program Files\XBMC\XBMC.exe
17:28:04 T:1484 M:1608601600 NOTICE: Log File is located: E:\Program Files\XBMC\xbmc.log
17:28:04 T:1484 M:1608601600 NOTICE: -----------------------------------------------------------------------
17:28:04 T:1484 M:1608577024 NOTICE: Setup SDL
17:28:05 T:1484 M:1608155136 NOTICE: load settings...
17:28:05 T:1484 M:1608130560 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:28:05 T:1484 M:1608126464 NOTICE: loading special://masterprofile/guisettings.xml
17:28:05 T:1484 M:1607794688 NOTICE: Enabled debug logging due to GUI setting
17:28:05 T:1484 M:1607794688 NOTICE: Getting hardware information now...
17:28:05 T:1484 M:1607794688 INFO: Using analog output
17:28:05 T:1484 M:1607794688 INFO: AC3 pass through is enabled
17:28:05 T:1484 M:1607794688 INFO: DTS pass through is enabled
17:28:05 T:1484 M:1607794688 NOTICE: Checking resolution 10
17:28:05 T:1484 M:1607790592 NOTICE: Setting autoresolution mode 1
17:28:05 T:1484 M:1607782400 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:28:05 T:1632 M:1607782400 DEBUG: thread start, auto delete: 0
17:28:05 T:1484 M:1607749632 NOTICE: Loaded playercorefactory configuration
17:28:05 T:1484 M:1607741440 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:28:05 T:1484 M:1607741440 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:28:05 T:1484 M:1607737344 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
17:28:05 T:1484 M:1607737344 NOTICE: Default DVD Player: dvdplayer
17:28:05 T:1484 M:1607737344 NOTICE: Default Video Player: dvdplayer
17:28:05 T:1484 M:1607737344 NOTICE: Default Audio Player: paplayer
17:28:05 T:1484 M:1607766016 NOTICE: special://masterprofile/sources.xml
17:28:05 T:1484 M:1607753728 DEBUG: Constructing surface 1280x720, shared=00000000, fullscreen=0
17:28:09 T:1484 M:1602670592 NOTICE: GL_VENDOR = SciTech Software, Inc.
17:28:09 T:1484 M:1602670592 NOTICE: GL_RENDERER = GLDirect 5.0 /x86/MMX/SSE (Jul 20 2004 03:15:21)
17:28:09 T:1484 M:1602670592 NOTICE: GL_VERSION = 1.4 Mesa 5.0
17:28:09 T:1484 M:1602670592 NOTICE: GL_EXTENSIONS = GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_convolution GL_EXT_compiled_vertex_array GL_EXT_fog_coord GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_polygon_offset GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_stencil_wrap GL_EXT_texture_env_add GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_MESA_window_pos GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap
17:28:09 T:1484 M:1602666496 DEBUG: Asking to resize surface to 1280 x 720
17:28:09 T:1484 M:1602666496 DEBUG: New size does not cover the screen
17:28:09 T:1484 M:1602662400 INFO: GL: Maximum texture width: 1024
17:28:09 T:1484 M:1602654208 INFO: load language info file: special://xbmc/language/English/langinfo.xml
17:28:09 T:1484 M:1599442944 INFO: load language fileConfusedpecial://xbmc/language/English/strings.xml
17:28:09 T:1484 M:1598955520 INFO: load keymapping
17:28:09 T:1484 M:1598943232 INFO: Loading special://xbmc/system/Keymap.xml
17:28:09 T:1484 M:1598627840 DEBUG: CButtonTranslator::Load - no userdata Keymap.xml found, skipping
17:28:09 T:1484 M:1598627840 INFO: Loading special://xbmc/system/IRSSmap.xml
17:28:09 T:1484 M:1598615552 DEBUG: CButtonTranslator::Load - no userdata IRSSmap.xml found, skipping
17:28:09 T:1484 M:1598615552 INFO: Checking skin version of: PM3.HD
17:28:09 T:1484 M:1598599168 INFO: Skin version is: 2.11
17:28:09 T:1484 M:1598599168 INFO: GUI format 1280x720 720p 16:9
17:28:09 T:1484 M:1598590976 INFO: creating subdirectories
17:28:09 T:1484 M:1598590976 INFO: userdata folder: special://masterprofile/
17:28:09 T:1484 M:1598590976 INFO: recording folder:
17:28:09 T:1484 M:1598590976 INFO: screenshots folder:
17:28:09 T:1484 M:1598554112 INFO: thumbnails folderConfusedpecial://masterprofile/Thumbnails
17:28:09 T:1484 M:1598410752 NOTICE: start dvd mediatype detection
17:28:09 T:1484 M:1598406656 NOTICE: initializing playlistplayer
17:28:09 T:1484 M:1598402560 NOTICE: DONE initializing playlistplayer
17:28:09 T:1484 M:1598398464 DEBUG: DPMS: supported power-saving modes: OFF STANDBY
17:28:09 T:1804 M:1598394368 DEBUG: thread start, auto delete: 0
17:28:09 T:1804 M:1598357504 DEBUG: Compiled with libcdio Version 0.72
17:28:09 T:1484 M:1598312448 NOTICE: load default skin:[PM3.HD]
17:28:09 T:1484 M:1598304256 INFO: load skin fromConfusedpecial://home/skin/PM3.HD
17:28:09 T:1484 M:1598304256 INFO: delete old skin...
17:28:09 T:1484 M:1598263296 INFO: Default 4:3 resolution directory is special://home/skin/PM3.HD/720p
17:28:09 T:1484 M:1598263296 INFO: Default 16:9 resolution directory is special://home/skin/PM3.HD/720p
17:28:09 T:1484 M:1598263296 INFO: Skin version is: 2.11
17:28:09 T:1484 M:1598251008 INFO: Loading skin includes from E:\Program Files\XBMC\skin\PM3.HD\720p\includes.xml
17:28:09 T:1484 M:1596891136 INFO: load fonts for skin...
17:28:09 T:1484 M:1596882944 INFO: Loading fonts from special://home/skin/PM3.HD/720p/Font.xml
17:28:09 T:1484 M:1595613184 INFO: load new skin...
17:28:09 T:1484 M:1595609088 INFO: Skin version is: 2.11
17:28:09 T:1484 M:1595609088 INFO: Loading skin file: Home.xml
17:28:09 T:964 M:1595432960 DEBUG: thread start, auto delete: 1
17:28:09 T:964 M:1595387904 INFO: WEATHER: Downloading weather
17:28:09 T:964 M:1595301888 DEBUG: Win32DllLoader::Load(special://xbmc/system/libcurl.dll)
17:28:10 T:964 M:1594286080 DEBUG: LoadLibraryA('MSVCR71.dll')
17:28:10 T:964 M:1594273792 DEBUG: Win32DllLoader::Load(MSVCR71.dll)
17:28:10 T:964 M:1594269696 DEBUG: LoadLibrary('MSVCR71.dll') returning: 02DEF7F8
17:28:10 T:964 M:1594249216 DEBUG: FileCurl::Open(0327FD5C) http://xoap.weather.com/weather/local/US...145f208494
17:28:10 T:964 M:1594179584 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://xoap.weather.com
17:28:10 T:1484 M:1593610240 DEBUG: Load Home.xml: 365.25ms
17:28:10 T:1484 M:1593602048 INFO: Loading user windows, path special://home/skin/PM3.HD/720p
17:28:10 T:1484 M:1593602048 INFO: Loading skin file: special://home/skin/PM3.HD/720p/custom_Credits_1112.xml
17:28:10 T:1484 M:1593569280 INFO: Loading skin file: special://home/skin/PM3.HD/720p/custom_SkinSetting_1111.xml
17:28:10 T:1484 M:1593356288 INFO: Loading user windows, path special://home/skin/PM3.HD/720p
17:28:10 T:1484 M:1593352192 INFO: Loading skin file: special://home/skin/PM3.HD/720p/custom_Credits_1112.xml
17:28:10 T:1484 M:1593421824 INFO: Loading skin file: special://home/skin/PM3.HD/720p/custom_SkinSetting_1111.xml
17:28:10 T:1484 M:1593352192 INFO: Loading user windows, path special://home/skin/PM3.HD/720p
17:28:10 T:1484 M:1593352192 INFO: Loading skin file: special://home/skin/PM3.HD/720p/custom_SkinSetting_1111.xml
17:28:10 T:1484 M:1593352192 DEBUG: Load Skin XML: 433.18ms
17:28:10 T:1484 M:1593352192 INFO: initialize new skin...
17:28:10 T:1484 M:1593352192 INFO: Loading skin file: Pointer.xml
17:28:10 T:1484 M:1593339904 DEBUG: Load Pointer.xml: 31.87ms
17:28:10 T:1484 M:1593307136 DEBUG: Alloc resources: 52.93ms (31.94 ms skin load)
17:28:10 T:1484 M:1593294848 INFO: Loading skin file: DialogVolumeBar.xml
17:28:10 T:1484 M:1593266176 DEBUG: Load DialogVolumeBar.xml: 28.45ms
17:28:10 T:1484 M:1593274368 DEBUG: Alloc resources: 29.36ms (28.52 ms skin load)
17:28:10 T:1484 M:1593266176 INFO: Loading skin file: DialogSeekBar.xml
17:28:10 T:1484 M:1593192448 DEBUG: Load DialogSeekBar.xml: 26.90ms
17:28:10 T:1484 M:1593171968 DEBUG: Alloc resources: 28.77ms (26.97 ms skin load)
Part - 2
17:28:10 T:1484 M:1593167872 INFO: Loading skin file: DialogKaiToast.xml
17:28:10 T:1484 M:1593155584 DEBUG: Load DialogKaiToast.xml: 12.53ms
17:28:10 T:1484 M:1593155584 DEBUG: Alloc resources: 12.59ms (12.59 ms skin load)
17:28:10 T:1484 M:1593155584 INFO: Loading skin file: DialogMuteBug.xml
17:28:10 T:1484 M:1593143296 DEBUG: Load DialogMuteBug.xml: 27.16ms
17:28:10 T:1484 M:1593143296 DEBUG: Alloc resources: 27.26ms (27.25 ms skin load)
17:28:10 T:1484 M:1593143296 DEBUG: CGUIAudioManager::Initialize
17:28:10 T:1484 M:1593294848 DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: Primary Sound Driver
17:28:10 T:1484 M:1593294848 DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: SoundMAX HD Audio
17:28:10 T:1484 M:1593294848 DEBUG: CWDSound::direct_sound_enumerator_member_callback - found Device: Realtek HDA HDMI Out
17:28:10 T:1484 M:1593364480 INFO: Loading special://home/skin/PM3.HD/sounds/sounds.xml
17:28:10 T:964 M:1593368576 DEBUG: FileCurl::Close(0327FD5C) http://xoap.weather.com/weather/local/US...145f208494
17:28:10 T:964 M:1593360384 INFO: WEATHER: Weather download successful
17:28:10 T:1484 M:1593171968 INFO: skin loaded...
17:28:10 T:1484 M:1587757056 DEBUG: Activating window ID: 12999
17:28:10 T:1484 M:1587757056 DEBUG: Checking if window ID 12999 is locked.
17:28:10 T:1484 M:1587757056 INFO: Loading skin file: Startup.xml
17:28:10 T:1484 M:1587658752 DEBUG: Load Startup.xml: 29.86ms
17:28:10 T:1484 M:1587658752 DEBUG: Alloc resources: 29.91ms (29.90 ms skin load)
17:28:10 T:1484 M:1587625984 INFO: removing tempfiles
17:28:10 T:688 M:1587548160 DEBUG: thread start, auto delete: 1
17:28:10 T:688 M:1587580928 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://www.google.com
17:28:10 T:1484 M:1587527680 NOTICE: initialize done
17:28:10 T:1484 M:1587527680 NOTICE: Running the application...
17:28:10 T:1484 M:1587290112 DEBUG: CApplication::ExecuteXBMCAction : Translating ReplaceWindow(Home)
17:28:10 T:1484 M:1587290112 DEBUG: CApplication::ExecuteXBMCAction : To ReplaceWindow(Home)
17:28:10 T:1484 M:1587351552 DEBUG: Activating window ID: 10000
17:28:10 T:1484 M:1587351552 DEBUG: Checking if window ID 10000 is locked.
17:28:11 T:1484 M:1586708480 DEBUG: Alloc resources: 42.03ms (0.00 ms skin load)
17:28:11 T:1484 M:1586688000 DEBUG: CNetwork::NetworkMessage - Starting network services
17:28:11 T:1484 M:1586688000 NOTICE: ES: Starting event server
17:28:11 T:780 M:1586651136 DEBUG: thread start, auto delete: 0
17:28:11 T:780 M:1586642944 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
17:28:11 T:780 M:1586642944 NOTICE: UDP: Listening on port 9777
17:28:11 T:1484 M:1586585600 DEBUG: CLastfmScrobbler: Clearing session.
17:28:11 T:1484 M:1586581504 DEBUG: CLibrefmScrobbler: Clearing session.
17:28:11 T:1484 M:1586569216 INFO: Resuming from suspend
17:28:11 T:1028 M:1589297152 DEBUG: thread start, auto delete: 0
17:28:11 T:1028 M:1589219328 DEBUG: Win32DllLoader::Load(special://xbmc/system/ImageLib.dll)
17:28:11 T:1484 M:1580380160 ERROR: GL: Image width 2048 too big to fit into single texture unit, truncating to 1024
17:28:11 T:1028 M:1580617728 DEBUG: LoadLibraryA('MSVCR71.dll')
17:28:11 T:1028 M:1580589056 DEBUG: LoadLibrary('MSVCR71.dll') returning: 02DEF7F8
17:28:11 T:1028 M:1580548096 DEBUG: LoadLibraryA('MSVCP71.dll')
17:28:11 T:1028 M:1580548096 DEBUG: Win32DllLoader::Load(MSVCP71.dll)
17:28:11 T:1028 M:1580548096 DEBUG: LoadLibraryA('MSVCR71.dll')
17:28:11 T:1028 M:1580544000 DEBUG: LoadLibrary('MSVCR71.dll') returning: 02DEF7F8
17:28:11 T:1028 M:1580544000 DEBUG: LoadLibrary('MSVCP71.dll') returning: 02DEAC78
17:28:11 T:1484 M:1578016768 ERROR: GL: Image width 2048 too big to fit into single texture unit, truncating to 1024
17:28:11 T:688 M:1576513536 DEBUG: FileCurl::Close(0402FD1C) http://www.google.com/
17:28:11 T:688 M:1576521728 DEBUG: Thread 688 terminating (autodelete)
17:28:11 T:1484 M:1576472576 ERROR: GL: Image width 2048 too big to fit into single texture unit, truncating to 1024
17:28:11 T:964 M:1574162432 DEBUG: Thread 964 terminating (autodelete)
17:28:11 T:1432 M:1577070592 DEBUG: thread start, auto delete: 0
17:28:11 T:1432 M:1577242624 DEBUG: FileCurl::Open(0422FD64) http://feeds.feedburner.com/xbmc
17:28:11 T:1432 M:1577177088 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://feeds.feedburner.com
17:28:11 T:1432 M:1573134336 DEBUG: FileCurl::Close(0422FD64) http://feeds.feedburner.com/xbmc
17:28:11 T:1432 M:1570742272 DEBUG: Got rss feed: http://feeds.feedburner.com/xbmc
17:28:11 T:1432 M:1570672640 DEBUG: RSS feed encoding: ISO-8859-1
17:28:11 T:1432 M:1570643968 DEBUG: Parsed rss feed: http://feeds.feedburner.com/xbmc
17:28:11 T:1432 M:1572847616 DEBUG: Thread 1432 terminating
17:28:15 T:1484 M:1575780352 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(ShutdownMenu)
17:28:15 T:1484 M:1575780352 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(ShutdownMenu)
17:28:15 T:1484 M:1575780352 DEBUG: Activating window ID: 10111
17:28:15 T:1484 M:1575780352 DEBUG: Checking if window ID 10111 is locked.
17:28:15 T:1484 M:1575780352 INFO: Loading skin file: DialogButtonMenu.xml
17:28:15 T:1484 M:1575751680 DEBUG: Load DialogButtonMenu.xml: 41.16ms
17:28:16 T:1484 M:1556332544 DEBUG: Alloc resources: 443.84ms (41.21 ms skin load)
17:28:16 T:1028 M:1550999552 DEBUG: Thread 1028 terminating
17:28:18 T:1484 M:1552605184 DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.Shutdown()
17:28:18 T:1484 M:1552605184 DEBUG: CApplication::ExecuteXBMCAction : To XBMC.Shutdown()
17:28:18 T:1484 M:1552449536 NOTICE: Storing total System Uptime
17:28:18 T:1484 M:1552449536 NOTICE: Saving settings
17:28:18 T:1484 M:1552347136 NOTICE: stop all
17:28:18 T:1484 M:1552347136 DEBUG: CNetwork::NetworkMessage - Stopping network services
17:28:18 T:1484 M:1552347136 NOTICE: ES: Stopping event server
17:28:19 T:780 M:1553100800 NOTICE: ES: UDP Event server stopped
17:28:19 T:780 M:1553100800 DEBUG: Thread 780 terminating
17:28:19 T:1484 M:1553125376 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
17:28:19 T:1484 M:1553108992 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
17:28:19 T:1484 M:1553096704 NOTICE: stop dvd detect media
17:28:19 T:1804 M:1553092608 DEBUG: Thread 1804 terminating
17:28:19 T:1484 M:1553117184 NOTICE: stop sap announcement listener
17:28:19 T:1484 M:1553113088 NOTICE: clean cached files!
17:28:19 T:1484 M:1553104896 NOTICE: unload skin
17:28:19 T:1484 M:1553104896 DEBUG: CGUIAudioManager:Big GrineInitialize
17:28:19 T:1484 M:1572286464 NOTICE: stop python
17:28:19 T:1484 M:1572286464 NOTICE: stopped
17:28:19 T:1484 M:1572286464 NOTICE: destroy
17:28:19 T:1484 M:1572241408 NOTICE: unload sections
17:28:19 T:1484 M:1572241408 DEBUG: SECTION:UnloadAll(DLL: special://xbmc/system/libcurl.dll)
17:28:19 T:1484 M:1572241408 DEBUG: Win32DllLoader::Unload libcurl.dll
17:28:19 T:1484 M:1572241408 DEBUG: FreeLibrary(MSVCR71.dll) -> 02DEF7F8
17:28:19 T:1484 M:1572806656 DEBUG: SECTION:UnloadAll(DLL: special://xbmc/system/ImageLib.dll)
17:28:19 T:1484 M:1572806656 DEBUG: Win32DllLoader::Unload ImageLib.dll
17:28:19 T:1484 M:1572806656 DEBUG: FreeLibrary(MSVCR71.dll) -> 02DEF7F8
17:28:19 T:1484 M:1572806656 DEBUG: FreeLibrary(MSVCP71.dll) -> 02DEAC78
17:28:19 T:1484 M:1572806656 DEBUG: Win32DllLoader::Unload MSVCP71.dll
17:28:19 T:1484 M:1572806656 DEBUG: Win32DllLoader::Unload MSVCR71.dll
17:28:19 T:1484 M:1584021504 DEBUG: CLastfmScrobbler: Journal with 0 entries saved to special://masterprofile/LastfmScrobbler.xml
17:28:19 T:1484 M:1583935488 DEBUG: CLibrefmScrobbler: Journal with 0 entries saved to special://masterprofile/LibrefmScrobbler.xml
Silverxxx Wrote:Hi, was searching for an answer to your problem and I came across this: http://glintercept.nutty.org/Ver0_5/
I tried it but did not work. The gliLog.txt says:
Quote:GL Intercept Log. Version : 0.5 Compile Date: Dec 3 2005 Run on: Sun Jul 05 17:43:18 2009
ShaderEditASM::Init - No asm OpenGL extension support.
ShaderEditASM::CreateInstance - Unable to init new ASM shader editor
ShaderEditGLSL::Init - Need OpenGL2.0 implementation to use the GLSL shader editor
ShaderEditGLSL::CreateInstance - Unable to init new GLSL shader editor
Need OpenGL version 1.1 or greater for image logging
The GLSL logger needs OpenGL 2.0 or better to run
Log End.
Two quick things. First, this post will tell you how to post a debug log.
http://forum.xbmc.org/showthread.php?tid=42708
Second, here is the line you are looking for.
That line says you SHOULD have a working XBMC, because the OpenGL version is 1.4.
Here is the line from your other computer.
This line says you should NOT having working XBMC, because the OpenGL version is only 1.1, when XBMC needs 1.4 or sometimes 1.3.
Yet windows's aint enough. And my ati's seems not to be detected by xbmc. Or ati doesnt do opengl but i quite belive they do. Mayby its there but not as xbmc would usualy want it to be... Koz the card is not a regular radeon, its a radeon mobile (mobility) and it has been deVistaized so it fits xp... It's the only way or to use genuine video crap drivers Tongue
natethomas Wrote:Two quick things. First, this post will tell you how to post a debug log.
OK. Thanks the link. Sorry for the "spam" post.
I have run this tests on the same laptop (better one, HP 8510p):
TEST RUN 1:
Results of running XBMC with the original opengl:
http://farm3.static.flickr.com/2436/3691...68.jpg?v=0
Quote:19:45:36 T:2056 M:922230784 NOTICE: GL_VENDOR = Microsoft Corporation
19:45:36 T:2056 M:922230784 NOTICE: GL_RENDERER = GDI Generic
19:45:36 T:2056 M:922230784 NOTICE: GL_VERSION = 1.1.0
TEST RUN 2:
Results of running XBMC with 3rd-party opengl (SciteCH GLDirect) opengl:
http://farm4.static.flickr.com/3646/3691...ae.jpg?v=0
Quote:19:40:56 T:3696 M:1145925632 NOTICE: GL_VENDOR = SciTech Software, Inc.
19:40:56 T:3696 M:1145925632 NOTICE: GL_RENDERER = GLDirect 5.0 /x86/MMX/SSE (Jul 20 2004 03:15:21)
19:40:56 T:3696 M:1145925632 NOTICE: GL_VERSION = 1.4 Mesa 5.0
19:40:56 T:3696 M:1145925632 NOTICE: GL_EXTENSIONS = GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_convolution GL_EXT_compiled_vertex_array GL_EXT_fog_coord GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_polygon_offset GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_stencil_wrap GL_EXT_texture_env_add GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_MESA_window_pos GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap
With TEST Run 2 XBMC starts but the screen quality is bad as you can see it in the link.
I feel like message we should all take from this is to stop downgrading from Vista to XP, if we want proper driver support using laptops. Wink
Flame away!
lol, NateThomas Smile
You know that vista is nothing compared to XP Tongue Even W7 seems to be too thingish Tongue I guess that even if i had a "core 4 hoctuple" at "16ghz" (imaginary computer) i would still prefer xp than vista Tongue (oem computermakers should know that)
Yet i can comfirm that on vista, xbmc will not run with a ati radeon mobile 2600 hd or other mobility items. The software just refuses to run. Mayby the opengl version is a bit diferant than pci/pci-e/agp radeon cards?
Anpe8; at least you can ge it to run Tongue (kidding, i know how sad it is to be unable to run our prefered applications Smile )
Matthieu Wrote:lol, NateThomas Smile
I have tried boxee as well. Same crashes. So my second best option is off as well. Smile
I wil try it a bit and let us see... Smile
Pages: 1 2
