Hi all,
i have installed XBMC like it shows in "xbmcbuntu how to".
The internet connection is ok, weather is working.
Any ideas?
Thx
Regards
Parti
Welcome!
Start trouble shooting for yourself. Do a debug log for instance. See the stickies and manual for more information. Once you have a better idea of what's going on, post some more info and we may be able to help
Cheers,
Jonathan
I need more assistans.
I enabled the debug mode and look into the xbmc.log. I am searching for something like the filename i use with the scrapper, or for something like ofdb or imdb. The only thing i can find was
CPlayerCoreFactory::GetPlayers(/media/daten1/Filme/2 Fast 2 Furious.mkv)
CFavourites::Load - no system favourites found, skipping
CFavourites::Load - no userdata favourites found, skipping
How can i look what the scrappers do?
Gruß
Parti
i also tried the xbmc 9.04.1 live cd. Tmdb and Ofdb (imdb not tested) Scrappers don't working. Any ideas?
