How does XBMC handles resolutions. Looking at my xorg.conf there are non listed but numerous ones available in the settings menu?
I want to set it up that only 480, 720p, 1080i and 1080p are showing and ideally 100% compatible with TV's.
They're handled by xrandr as in every recent linux distro. You should have a look at "modelines" if you want to craft your own (this has nothing to do with xbmc, so you're better of at the ubuntu forums or a simple google).
Haggy Wrote:They're handled by xrandr as in every recent linux distro. You should have a look at "modelines" if you want to craft your own (this has nothing to do with xbmc, so you're better of at the ubuntu forums or a simple google).
Cheers the direction. I messed about with modelines ages ago. Xrandr is new to me. Will look it up.
Xrandr relies heavily on what your display reports (EDID information). Unforunately a lot of EDID resolutions and refresh rates coming from TVs are totally crap. Writing your own - or falling back to modelines - would be your best option.
As a reference you could have a look at mine:
http://sprunge.us/iYcF
Haggy Wrote:Xrandr relies heavily on what your display reports (EDID information). Unforunately a lot of EDID resolutions and refresh rates coming from TVs are totally crap. Writing your own - or falling back to modelines - would be your best option.
As a reference you could have a look at mine: http://sprunge.us/iYcF
yeah I recall playing with mythtv about 4 years ago and getting frustrated with modelines working with the plasma properly.
Thanks for that example, really appreciate it. Has all the 1080p ones I want and just need to sort out the 720p and 480p should they be required. I have a 1080p plasma and then a HD ready plasma and LCD to test with.
Haggy Wrote:As a reference you could have a look at mine: http://sprunge.us/iYcF
Hahaha
Option "NoLogo" "True" # we're not myspace
