Full Version: 360 wireless controller; ignored by XBMC
I've searched all over to see if anyone else was having this issue but I haven't seen anyone else run into this; figured I'd make a post!
My Xbox 360 wireless controller stopped working on XBMC a month or so ago, but I was too busy with work to really look into it. Now that I've come back to XBMC, I'm stuck with the controller now working again. The controller works in any other program (and even Plex), but XBMC won't work with it. When I checked the log file I noticed this:
19:26:36 T:2686537632 M:456224768 INFO: Available videomodes:
19:26:36 T:2686537632 M:456224768 INFO: Found mode: 1920x1080
19:26:36 T:2686537632 M:456224768 INFO: Found mode: 1280x720
19:26:36 T:2686537632 M:456224768 INFO: Found mode: 1024x576
19:26:36 T:2686537632 M:456224768 INFO: Found mode: 800x600
19:26:36 T:2686537632 M:456224768 INFO: Found mode: 720x480
[COLOR="black"]19:26:36 T:2686537632 M:456220672 NOTICE: Ignoring joystick: Wireless 360 Controller[/COLOR]
Does anyone have any idea why that may be happening, did XBMC drop 360 controller support that I wasn't aware of? It seemed to happen out of nowehere, and the controller certainly does work in other applications; but any help would be much appreciated Smile !
Please read the sticky about reporting a problem in a useful manner. That includes a full debug log onto pastebin.com and preferrably some of your config files like Keymap.xml.
Sorry about that; here's some more of my information now that I went over the posting tips:
OSX Version: 10.5.5
Platform : Mac Mini 1.83ghz
Install Method: dmg
SVN Revision: I've had the issue with every version from version 9.04 (Babylon) to the very latest SVN version (if you need a specific version, the one I'm using right now is r21421)
My debug log can be viewed at http://pastebin.com/m7c11227c
My keymap can be viewed at http://pastebin.com/m412155f6 - though with or without the keymap file I get the same exact error.
If there's anymore information I need to put I can, hope this is enough though Wink
I guess no one else has this problem!
Is there anyone out there who is still successfully using their 360 controller with XBMC on their mac? If there is, post a reply - at least then I'll know it's probably something on the mac side as opposed to XBMC.
This is an old thread, but I am having this exact issue. Did anyone ever fix it?
