Full Version: [REQUEST] Smaller Video OSD (On Screen Display) Controls?
The current Aeon video controls are huge they take up a lot of space
If you look at Windows Media player its about half the size
so i was just wondering if someone who actually knew how to do this stuff could slim down the bar
the way you control it is kinda weird with the keyboard so is it possible to change the default keys
Thank You
wooowman93
Part of the problem is that you are using a 16:9 skin on a 4:3 display. If you get a media center remote you don't even need to use the keyboard for normal operation and it makes things a lot easier.
It could be that he's using a 720p display with non-square pixels though.
