2009-07-07, 11:03
Pages: 1 2
2009-07-07, 19:36
You can add sort tokens by using advancedsettings.xml . You can search the wiki for exact directions, or paste this text into a file called advancedsettings.xml and put it in your userdata folder.
Edit: Just to clarify, adding these tokens will make xbmc ignore them when sorting movies (so "L'Enfants" would be sorted under "E"). I assumed this was what you were asking. You can add more tokens by separating them with a | (pipe).
<?xml version="1.0" encoding="UTF-8"?>
<advancedsettings>
<sorttokens>the|l'</sorttokens>
</advancedsettings>
2009-07-08, 00:17
This is what I have in advancedsettings.xml
But, the L apostrophe doesn't work.
<sorttokens>
<token>the</token>
<token>a</token>
<token>le</token>
<token>la</token>
<token>les</token>
<token>l'</token>
</sorttokens>
2009-07-08, 01:13
unless those movies are named 'l' ', that is the ' is followed by a space, it won't work
2009-07-08, 12:58
That's what I figured. Is it hard to change the code to treat ' as a delimiter? Or do I have to rename all of my movies (approx 100 like this) instead?
2009-07-08, 13:09
it's not hard, see StartsWithToken in SortFileItem.cpp
2009-07-08, 15:51
Ok, I figured it out.
For anyone interested, open up Settings.cpp and locate this code at line 1376
And change it to this:
And in your advancedsettings.xml
if (pToken->FirstChild() && pToken->FirstChild()->Value())
g_advancedSettings.m_vecTokens.push_back(CStdString(pToken->FirstChild()->Value()) + " ");
g_advancedSettings.m_vecTokens.push_back(CStdString(pToken->FirstChild()->Value()) + ".");
g_advancedSettings.m_vecTokens.push_back(CStdString(pToken->FirstChild()->Value()) + "'");
<sorttokens>
<token>l</token>
</sorttokens>
2009-07-08, 16:26
trac a diff and i'll see if we can't do this by default
cheers
cheers
2009-07-08, 18:51
spiff:-
Maybe we should specific the token delimeter in our advancedsettings if we aren't already ..
2009-07-08, 20:42
2022-11-10, 04:10
I realize how old this thread is, but it's very close in relevance to what I'm trying to fix. I have a few movies that start with an apostrophe < ' >, followed by a word, such as 'Twas or 'Tis, but I can't get Kodi to ignore the apostrophe with the sort tokens, so it sorts them by the letter 'T'. I also tried adding a "blank" separator like below, but that also didn't work.
Is there a way to accomplish this?
<token separators="'"></token>
2022-11-10, 05:29
(2022-11-10, 04:10)Skirge01 Wrote: [ -> ]<token separators="'"></token>Can you try the following and see if it works. I think the problem is that you need to add a value.
xml:<sorttokens>
<token separators="'">T</token>
</sorttokens>
2022-11-10, 10:59
I don't think you need the separator in this case, as I believe that's only needed you have a sort article including a delimiter with no space to what you want to sort by.
So you could also try
<token>'T</token>
xml:
2022-11-10, 11:08
Actually thinking about I'm not sure this is an appropriate use of sort tokens, so I'm not convinced anything would work.
2022-11-10, 11:18
After some more thought I wonder is this would work
So the apostrophe is both the token and separator, since I believe the way it works is
<sort token><separator><word on which sort begins>
xml:<token separators="'">'</token>
Pages: 1 2
