2009-07-23, 20:04
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2009-07-23, 20:07
Aenima99x Wrote:**UPDATE**
Added new Media Flag icons for AAC, BluRay, & H264.
Thanks again to SlaveUnit.
Dont anyone be too worried about the bluray one. Its the same logo just a tiny bit bigger so it matches the others more.
Link for latest with both sets of new flags.
http://www.mediafire.com/?sharekey=92802...0a1ae8665a
2009-07-23, 22:23
Aenima99x Wrote:http://forum.xbmc.org/showpost.php?p=358...stcount=34
Thanks for the link, I'll look into it.
Did you get a chance to look into it? sorry to bother you, I just think it makes so much sense to have it show you your latests albums, if not, you just get a list of the 5 songs of the last album...
If you don't think it's better, I just need some help to find in which xml the script is called so I can change it myself
thanks a lot for this great mod!
2009-07-24, 02:43
**UPDATE**
Recently Added Music now shows latest albums instead of songs.
Recently Added Movies now shows single thumbs and changes them accordingly.
One thing to note though, the Recently Added Music will only play the first song on the album and then exit. This is a known issue by Nuka and will need to be fixed in the script by him.
2009-07-24, 04:56
Hi Yall
check these /// OSD while in the menus
a toggle to turn it on/off in left blade (having it sliding in/out) would be sooo cool !!!
( waay beyond my copy/paste skills, but did you notice the fade )
anyone care to do this properly
EDIT // i thought it would be more difficult
but i just copied <control type="videowindow">
to <include name="SmallVideoInfo">
added <visible>Player.HasVideo</visible>
now it shows a tiny tiny video stream
when using the small video display too
2009-07-24, 05:02
You want the now playing to show while you're browsing the library? I think it's fine in the slide out menu.
2009-07-24, 05:36
this is is cool.
is it too difficult to leave the stacking when on the movies page
but load them individually when they are selected ?
2009-07-24, 06:19
Aenima99x Wrote:You want the now playing to show while you're browsing the library? I think it's fine in the slide out menu.
with all due respect, your work is awesome. but we disagree on which UI elements or essential on-screen. i find keeping the video visible at all times key to maintaining engagement with the content. its like a car where you can only see the speed if your hold [this] button. while browsing the library, hearing the sound only, (unless the menu is open) is annoying & there needs to be a way for it to remain visible.
im mealy suggesting an idea so the skin can lend its-self to a "multi-threaded" experience. if yall agree, others can benefit. otherwise -- what is the best way to keep my hak sync'ed with your updates ?
PS // i switched to the Hoz menu
can you please make "BigVideoInfo" slide further down ?
it took a while to do this, but i got a snap
this is ~aprox~ where it stops before the view changes
2009-07-24, 14:23
Maybe fullscreen video in the homepage only, but with an option to turn it on/off
2009-07-24, 15:27
Im getting the old recenty added movies display & songs instead of albums.
Doubled checked that i updated from github & download the zip just to make sure & im still getting the old above displays.
2009-07-24, 15:55
zosky Wrote:this is is cool.
I couldn't get it to work, so it's staying as is for now.
2009-07-24, 16:02
zosky Wrote:with all due respect, your work is awesome. but we disagree on which UI elements or essential on-screen. i find keeping the video visible at all times key to maintaining engagement with the content. its like a car where you can only see the speed if your hold [this] button. while browsing the library, hearing the sound only, (unless the menu is open) is annoying & there needs to be a way for it to remain visible.I don't feel like the skin can keep it's integrity if something like this was added. In my opinion, it would just clutter up the views. The only view I'd even consider adding it to would be Fanart.
2009-07-24, 16:08
buges Wrote:Im getting the old recenty added movies display & songs instead of albums.
Not sure how? What are the dates on the following files -
720p/IncludesHomeRecentlyAdded.xml
720p/IncludesHomeRecentlyAdded2.xml
scripts/RecentlyAdded.py
2009-07-24, 16:43
Just done another remote fetch from Git Gui & all is up to date again.
Just to confirm date was 18th July
2009-07-24, 16:46
Ok cool.
