I want to display a texture only when songs are visible [Container.Content(songs)] but it doesn't work for the Top 100 Songs.
Is there a specific container ID for this?
Looks like that needs to be fixed. If it shows content that are songs, then Content(songs) should be true. Post a ticket on trac with the necessary details (i.e. an example skin, or mod to PM3.HD that shows the problem) and someone will take a look.
Cheers,
Jonathan
Does that have anything to do with this weird view?
I assumed it was just a skin thing with aeon. Same thing happens with search results and latest albums.
absolutely not related - that is definitely an aeon screwup.
zag2me Wrote:Does that have anything to do with this weird view?
I did find it when I was fixing that particular problem (which you can check at my GitHub fork below) but also tried it on PM3.HD, which JM suggested, and got the same results.
