2004-08-28, 10:49
2004-08-31, 11:53
hi bobrooney,
at the moment you can only have 1 of these. where you put it is up to you.
cheers,
jonathan
cheers,
jonathan
2004-08-31, 13:26
thanks for your answer and for all your great work to xbmc!
:bowdown:
:bowdown:
2004-08-31, 18:19
i was playing around with using it to render the entire home page on top of the original one with different buttons.
so basically you press one button labeled "more.." and up pops six new buttons. :p
anyways...i'm just rambling.
it is certainly an interesting feature that can be used in many different ways.
2004-09-01, 14:12
yes - it's basically a full window that acts as a dialog - when a button is pressed it performs the required action and then exits.
it should be able to be placed whereever you like.
