2012-10-21, 14:49
2012-10-30, 20:25
@Finchy, try:
sudo service lightdm stop
to stop XBMC and
sudo service lightdm start
to start it again.
to stop XBMC and
to start it again.
2012-10-31, 01:01
Dear users
I followed all of these steps but the problem remains the same, no visual on the screen. I think I did everything fine so here is my xorg.conf and xlog file hoping you guys could take a look at it.
Much appreciated
Joris
xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 304.60 (buildmeister@swio-display-x86-rhel47-13) Sun Oct 14 21:19:18 PDT 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
Option "ExactModeTimingsDVI" "TRUE"
HorizSync 30 - 83
VertRefresh 58 - 62
ModeLine "1280x720" 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync InterLace
SubSection
modes "1280x720"
EndSubSection
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "ModeValidation" "NoEdidModes"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
xlog.txt
This is a very long file, I uploaded it here:
http://users.telenet.be/clem.vanhouche/xlog.txt
Much appreciated
Joris
Much appreciated
Joris
xorg.conf
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
HorizSync 30 - 83
VertRefresh 58 - 62
SubSection
modes "1280x720"
EndSubSection
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
xlog.txt
Much appreciated
Joris
2012-10-31, 02:23
@Moddieman
remove Option "ModeValidation" "NoEdidModes"
remove SubSection
modes "1280x720"
EndSubSection
Under device add
Option "ModeDebug" "true"
Then I would like you to reboot and get me your /var/logs/xorg.0.log in a pastebing and I will calculate your modelines and do you a proper xorg...The old one is useless I want edid modes to show up pls on log.
uNi
remove SubSection
modes "1280x720"
EndSubSection
Under device add
uNi
2012-10-31, 05:46
@ Moddieman
@ Finchy
Use this xorg, and follow my link to properly configure xbmc for 23/24p
And that should give you pretty precise modes with nVidia 304.60
+1
uNi
@ Finchy
# Tweaked by uNiversal
Section "Device"
Driver "nvidia"
Option "NoLogo" "true"
Option "DynamicTwinView" "false"
Option "NoFlip" "false"
Option "ConnectToAcpid" "0"
Option "ModeValidation" "NoVesaModes, NoXServerModes"
Option "UseDisplayDevice" "DFP-1"
Option "ConnectedMonitor" "DFP-1"
Option "HWCursor" "false"
Option "SWCursor" "false"
Option "RenderAccel" "1"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "ColorRange" "Full"
Option "ColorSpace" "RGB"
Option "ExactModeTimingsDVI" "True"
Depth 24
EndSubSection
EndSection
Section "Monitor"
ModelName "Unknown"
HorizSync 30.0 - 83.0
VertRefresh 58.0 - 62.0
# 1920x1080p @ 23.976Hz (EIA/CEA-861B)
Modeline "1920x1080_60" 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
ModeLine "1920x1080_23.976" 74.175 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
ModeLine "1920x1080_24" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Option "DPI" "96 x 96"
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
+1
uNi
2012-10-31, 15:19
Thanks so much! I used the xorg you provided and everything works like an absolute charm. The only thing left do do for me is fixing the sound through hdmi but there is lots of documentation for this so i know this won't be a problem.
Thanks for the help, I really appreciate it!
Moddieman
Moddieman
2012-10-31, 16:36
(2012-10-31, 15:19)Moddieman Wrote: [ -> ]Thanks so much! I used the xorg you provided and everything works like an absolute charm. The only thing left do do for me is fixing the sound through hdmi but there is lots of documentation for this so i know this won't be a problem.Your welcome +1
Moddieman
uNi
2012-11-01, 02:45
This computer home theater software I have not tried it, I was very interested.
2012-11-01, 12:33
(2012-10-31, 05:46)uNiversal Wrote: [ -> ]@ Moddieman
@ Finchy
Code:# nvidia-xconfig: X configuration file generated by nvidia-xconfig
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Monitor"
ModelName "Unknown"
EndSection
EndSection
+1
uNi
Hi Universal
How do I get that into the Xorg file? When I try to paste it in via WinSCP it says action denied. I'm not very familiar with Linux editing, etc.
I'm running XBMCBuntu and my TV is a Panasonic 42PX60 btw.
2012-11-01, 14:24
You have do it via ssh (since your scp doesnt have permissions to create files everywhere then and paste the contents then press ctrl+o to save file and ctrl+x to exit back
Telling me what your tv brand and model is doenst help at all, as I cant see your /var/log/xorg.0.log and I dont have access to your Tv/system
This xorg is using DFP-1 since idk if your output is using DFP-0 or DFP-1 this may have to be modified to your system (you can find out by looking at /var/log/xorg.0.log instructions are on first post)
I also pimped the xorg to use Moddieman refresh rate for his TV. If you want a similar one you have to post the info he posted.
uNi
sudo nano /etc/X11/xorg.conf
uNi
2012-11-01, 18:26
Ah, thanks. I've updated the xorg.conf as you've said, but it still only gives me the resolution of up to 720p in XBMCBuntu.
I've uploaded my xorg.o.log file (copied into a .txt file) to https://dl.dropbox.com/u/11513453/Xorg.o.log.txt if you wouldn't mind having a look.
Many thanks
Many thanks
2012-11-01, 19:07
Ah ok, first off, its as I suspected, your TV and most like all tv's are DFP-0
Use this for your TV specific. Ive corrected the xorg to match your TV including
HorizSync : 15.000-46.000 kHz
VertRefresh : 48.000-61.000 Hz
As for 1920x1080 Your Tv supports @60Hz interlaced only @50Hz non interlaced which @50Hz is what I defined.
your xorg complains
If the xorg above doesnt set your TV to correct 1920x1080 we may have to replace this
with this
You will need to reboot after each xorg modification for safe measure.
If it still doesn't work we can comment out
put a # before -Option-
I cant be sure that it fixes it but it could be your TV is very picky (it is) and has a crap upscaler
You could also upgrade your video drivers to 304.60 if you haven't already done that. (xswat ppa)
uNi
Section "Device"
Driver "nvidia"
Option "UseDisplayDevice" "DFP-0"
Option "ConnectedMonitor" "DFP-0"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
Option "VertRefresh" "DFP-0: 15-36"
Option "HorizSync" "DFP-0: 48-61"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Monitor"
ModelName "Unknown"
HorizSync 15 - 36
VertRefresh 48 - 61
# 1920x1080p 50Hz to 23.976Hz (EIA/CEA-861B)
Modeline "1920x1080_50" 74.25 1920 2448 2492 2640 1080 1084 1089 1124 +hsync +vsync
EndSection
EndSection
your xorg complains
[ 20.480] (II) NVIDIA(0): Validating Mode "1920x1080":
[ 20.480] (II) NVIDIA(0): 1920 x 1080 @ 60 Hz
[ 20.481] (II) NVIDIA(0): Mode Source: EDID
[ 20.481] (II) NVIDIA(0): Pixel Clock : 74.18 MHz
[ 20.481] (II) NVIDIA(0): HRes, HSyncStart : 1920, 2008
[ 20.481] (II) NVIDIA(0): HSyncEnd, HTotal : 2052, 2200
[ 20.481] (II) NVIDIA(0): VRes, VSyncStart : 1080, 1084
[ 20.481] (II) NVIDIA(0): VSyncEnd, VTotal : 1094, 1124
[ 20.481] (II) NVIDIA(0): H/V Polarity : +/+
[ 20.481] (II) NVIDIA(0): Extra : Interlace
[ 20.481] (II) NVIDIA(0): Mode (1920 x 1080) is too large for DFP Native Resolution
[ 20.481] (II) NVIDIA(0): (Max: 1280 x 720); mode will not be allowed to scale
[ 20.481] (II) NVIDIA(0): to the DFP's native resolution.
[ 20.481] (II) NVIDIA(GPU-0): BestFit Scaled and BestFit AspectScaled are identical;
[ 20.481] (II) NVIDIA(GPU-0): collapsing BestFit AspectScaled.
[ 20.481] (II) NVIDIA(GPU-0): BestFit Centered and BestFit Scaled are identical;
[ 20.481] (II) NVIDIA(GPU-0): collapsing BestFit Scaled.
[ 20.482] (II) NVIDIA(GPU-0): BestFit Centered 1920x1080
[ 20.482] (II) NVIDIA(GPU-0): Horizontal Taps 0
[ 20.482] (II) NVIDIA(GPU-0): Vertical Taps 0
[ 20.482] (II) NVIDIA(GPU-0): Base SuperSample x4
[ 20.482] (II) NVIDIA(GPU-0): Base Depth 32
[ 20.482] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 20.482] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 20.482] (II) NVIDIA(0): Mode is valid.
Modeline "1920x1080_50" 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
with this
[code]Modeline "1920x1080_60i" 74.18 1920 2008 2052 2200 1080 1084 1089 1124 +hsync +vsync
uNi
2012-11-01, 20:17
Great, thanks, I'll have a go!
So does my telly support 1080p at 50hz?! I always thought it was 720p or 1080i.
How do I update my drivers (or find out what I have)?
2012-11-01, 21:03
OK, so I've updated the Xorg file but there's a problem. I get visuals until XBMC starts to load, but then I just get a black screen. I suspect it's because my telly doesn't support 1080p. I've just changed it back to the original (backup) one for the time being. Would you mind amending it to allow both 720p and 1080i please?
2012-11-01, 23:05
Replace the modeline as I said use the one I posted last except you want to replace
With
As for drivers its in xbmc.log
updating follow http://hometheatersalsa.com/updated-linu...a-drivers/
According to xorg.0.log the Tv supports 1080p @50Hz or 1080i interlaced @ 60Hz but xorg.log complains about 1080 modes in ANY interlaced or non interlaced. but try to replace the modelines as I instructed on both posts.
uNi
With
uNi
