Full Version: New panels for redux and mediastream
There has always been some panels i didnt like in mediastream.
So i changed them to fit my likings, thought i could
share with this comunity.
If any1 on a windowz comp trys it it would be nice if you could post some
screen grabs of the new panels Wink
Thanks to Paul this is now a them. Just grab the XPR file and copy
it alongside the other xpr file in the media folder. Then it should
be selectable from the theme selector in the skin.
http://www.4shared.com/file/118382178/60...ptile.html
Source files: (you dont need this for the them to work, only if you want to edit the files)
PNG files: (just put them in your /mediastream/media folder, yes you need to unpack files first)
http://www.mediafire.com/?rjb2mfm1zp0
Also the PSD source files if any one wants to mess around:
http://www.mediafire.com/?txszozn3vkj
Tried in both Mediastream and Redux with no results. Just see the same smooth panel backgrounds.
Extracted all 5 .png's in the media folder next to the .xpr files. Running on Windows.
mach170 Wrote:Tried in both Mediastream and Redux with no results. Just see the same smooth panel backgrounds.
I think you will need to compress those files to an xpr then choose that file under appearance/ theme it should then use those panels over the ones in the textures.xpr
But if your running Redux then just overwrite the existing files with the new onesSmile
Just tried this on redux and it works fine, if any body wants the reptile.xpr theme file ya can get it here http://www.4shared.com/file/118382178/60...ptile.html
Just pop it into your media folder along side textures.xpr
The select that file in settings / appearance then pick it under themes.Smile
thanks alot Paul, i didnt realize that puting png's outside
xpr's no longer work in xbmc Wink
The-Boxhead Wrote:thanks alot Paul, i didnt realize that puting png's outside
When and why did that change?
It never worked if you are replacing current ones XPR gets preference on loading images if a file with the same name is inside and outside the xpr the xpr one will be used always
Thats why we made XPR themes so people can change every texture if they want and just selecct the theme xpr in settings
Cheers, I must have got confused with adding extra images not in the XPR.
yeah prolly the same with me Wink
Your welcome, glad to be of helpSmile
