I have my Apple TV now for 2 weeks. After some hardcore testing, i have some probs.
I have a problem that my Xvid's and Divx don't run properly on my Apple TV. Neither in Nito TV nor in XBMC. I have 2.4 firmware on it and patched it using the ATVUSB Creator.
All files are on the Harddrive of the ATV and i am not streaming.
Basically what is happening is that every once in a while the picture stands still for a tenth of a second but the sound goes on. This is kind of annoying.
Has anyone experienced that as well ? Can anyone help me ?
DrPepper
ooh ok, didn't know, sorry
So Here my specs:
Apple TV with Launcher 3.1
The SVN:21559M however I had the problem also with other builds.
Here is the xbmc.log
http://pastebin.com/m2360f65e
Here is the CrashReport log:
http://pastebin.com/m4ca0a2a4
Let me know if you need anything else.
Thanks in advance for the help, much appreciated.
DrPepper
Ok,
one thing I see is that the output is 29.97 fps, however it should be 25 as I have a PAL TV Set and that the output resolution is also 50hz.
Could that be the cause ?
If yes, how can I change this 29.97fps to 25 fps ?
20:59:07 T:51625472 M: 3244032 NOTICE: fps: 29.970030, pwidth: 704, pheight: 288, dwidth: 704, dheight: 288
20:59:07 T:51625472 M: 3235840 DEBUG: OutputPicture - change configuration. 704x288. framerate: 29.97
20:59:07 T:51625472 M: 3158016 NOTICE: Display resolution AUTO : 1280x720 @ 50.00Hz (Full Screen) (12)
Or could it be this:
21:00:43 T:53275136 M: 5550080 DEBUG: CDVDPlayerAudio:: Discontinuty - was:95564076.284791, should be:95448000.000000, error:-116076.284791
21:00:44 T:53275136 M: 4296704 DEBUG: CDVDPlayerAudio:: Discontinuty - was:96458725.320000, should be:96424216.608399, error:-34508.711601
21:16:57 T:53275136 M: 3067904 DEBUG: CDVDPlayerAudio:: Discontinuty - was:96789627.059399, should be:1055768098.667359, error:958978471.607959
21:18:32 T:53275136 M: 3289088 DEBUG: CDVDPlayerAudio:: Discontinuty - was:1051170588.046359, should be:1124987597.065672, error:73817009.019313
21:19:28 T:53275136 M: 65323008 DEBUG: CDVDPlayerAudio:: Discontinuty - was:1117393315.330672, should be:1154315181.241600, error:36921865.910928
21:26:32 T:53275136 M: 61906944 DEBUG: CDVDPlayerAudio:: Discontinuty - was:1151384788.069600, should be:1188321597.111816, error:36936809.042216
Thanks in advance
DrPepper
reinstalled everything yesterday evening, still having the same problem....
Is there noone who can help or give me a hint
I really would appreciate some help or comments !
DrPepper
