Full Version: New episodes not adding to library ?
Hi there,
I'm having a problem where if I add some new TV shows to my NAS, when I run XBMC and it looks to add new items to the library, they just do not show up. New files on the same NAS, added the same way all work, it's just TV shows that don't get added. If I go into file mode, I can see them and play them fine.
Any ideas on what I may be doing wrond, or where I can help to fix this ?
Thanks,
Roy.
debug log of you doing a scan
Do you want this with an empty library ie. after it has scanned and not added them, and then scan again, or do you want it with them fresh and then do a scan ?
Roy.
fresh + new scan to be sure we don't loose any info
Ok, I've got a log file. But everytime I try to upload it to pastebin.com I get:
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 128 bytes) in /home/pastebin/lib/geshi/geshi.php on line 2729
Log is 4.39Mb in size. Ideas ?
Roy.
I went and used Movie Info Plus and generated .nfo files for all my tv shows. I then went in and ran Scan for New Content on the directories and this time it picked all the files up with no problems.
Roy.
