I am running the latest SVN build and I am getting the following message:
file: "<directory>default.py", line 11, in? xbmcplugin.addsortmethod(int(sys.argv[1]), xbmcplugin.sort_method_none)
attributerror: 'module' object has no attribute 'argv'
Any ideas?
Please add it to the Official Online Repository for all open source plugins ..
CrashX Wrote:Please add it to the Official Online Repository for all open source plugins ..
I've asked for access with no response...
Quote:I am running the latest SVN build and I am getting the following message:
Any ideas?
I will look in to it this evening...
precurser Wrote:I am running the latest SVN build and I am getting the following message:
Any ideas?
Hmmm... not getting that on my install...
Is there something more I can do to help describe my issue?
I am running XP Professional, with all the latest updates. I am running XBMC pre-9.10 r23458 (Compiled : Oct 8 2009).
I have the script installed at C:\Documents and Settings\george\Application Data\XBMC\scripts\FoodNetwork"
Is there any more info I can give you? What build are you running that it works on?
I get the exact same error message when trying to run your HGTV script as well...
precurser Wrote:Is there something more I can do to help describe my issue?
Maybe because you installed it in scripts folder... it should go in a plugin folder.
Amet.... Wow, I'm a f*cking idiot... Thanks for pointing that out to me, I guess I was thinking it was a script because I haven't manually installed any plugins, I have always used the installer within XBMC...
Thanks again man. Excuse my idiocy.
And thanks for the plugin MPauley.
is there a way to add "dinner: impossible" to the show list
also it doesn't look like new episodes are being loaded in the plugin. can that be fixed?
I don't know if this plugin is still being updated but it appears that it no longer works.
See Pastebin
I was able to use Blip.tv and the new HGTV plugin. See my attempts at using the foodnetwork at the bottom. Too bad too because otherwise this plugin would be great!
Look for a new release this week...
Any news to this one working? My wife has been asking about it
