2009-07-25, 03:20
I've done a lot searching over the past couple months, and have not been able to find a decent solution for my current hardware. I'm thinking I just need a different video card. I've read that the nvidia 9400 series is recommended, so I'm looking at this card..
GIGABYTE GV-N94TOC-1GI GeForce 9400 GT 1GB 128-bit GDDR2 (links to newegg)
Before I buy, I just want to make sure I need it. I've listed my system specs below. I run XBMC on ubuntu (no gui) and do mild-downloading in the background. I'm using digital audio, and the remote works great. I've got the Aeon skin as well. When I play a 1080p movie, the debug info has VQ staying max'ed at 99% the majority of the time. That's when video gets choppy. When it lowers, of course, the videos fine. I've tried to find out what VQ tells me, but I haven't had much luck with that. I'm aware that FFMpeg doesn't do multithreding. The highest I saw any of the cores get was 85% (Staying mostly 50-70). From what I've read with the correct video card, you can off-load a lot of the work from the cpu. The thing is, the video card I have should be plenty for 1080p. I had windows installed at one point with XBMC, and it worked fine on there.... but I need linux! I have onboard HDMI as well, that handled 720p pretty good. So any suggestions? (I'm new to posting!)
:: SOFTWARE ::
Ubuntu Januty 9.04
XBMC 9.40.1 r20654 (installed via apt-get)
:: HARDWARE ::
AMD Phenom 9500
2gb DDR2 800 (Usually has 1.4gb free)
MB: EVGA 113-M2-E113 AM2+/AM2 NVIDIA nForce 730a (links to newegg)
Vid: XFX PVT71PUDD3 GeForce 7900GS 256MB 256-bit GDDR3 (also links to newegg)
:: SOFTWARE ::
Ubuntu Januty 9.04
:: HARDWARE ::
AMD Phenom 9500
