2009-07-26, 16:26
Hello good people,
This is my first post, so please forgive me if my question has been asked before. I did some searching, but I couldn't find an answer.
My question is: can I use the disc number field in ID tags to list my music files? I use it often with multi-discs albums, like operas for instance, so that I can put all the files in the same directory. This way, I just start the music and it plays continuously until the end. The problem is that with the regular naming scheme, the files get listed by their track number only, which puts all the #1 tracks together, then the #2, then #3, etc. Very annoying when you want to listen to Madama Butterfly. If I could just use the filename instead of a naming scheme (i.e. %N. %A-%T) in the options, that would be just fine, but if there is a "%X" code for disc numbers, that would be even better. Is there a way to use non-listed tag fields in the naming schemes? I know it seems obvious, but when you don't know it, you have to ask...
Thanks a lot!
Thanks a lot!
