2009-07-29, 01:02
I've combed over a lot of forums but I can't seem to find a resolution to my issue...
Here are my relevant specs:
Ubuntu Jaunty 9.04
Linux-x86
PPA
XBMC 9.04.1 r20654
NVIDIA Driver Version: 185.18.14 (I understand beta drivers aren't supported but I am using them only because I have tried 180 that comes with Jaunty and had the same result)
PNY 8400 GS PCI with 512 mb ram
...The problem is that the drop down under Player -> Render Method doesn't have VDPAU as an option.
I can access the NVIDIA X Server Settings to see that my graphics driver is running correctly. I can also verify that the XBMC UI is running nicely and the desktop effects are enabled.
At this point, all I can think is that my graphics card doesn't have the G98 chip support, but everything I've read has indicated that it does. Or, XBMC is checking something to identify VDPAU support and not finding it. I'm hoping it's the latter and I can force it somehow.
Any help would be much appreciated!
Ubuntu Jaunty 9.04
Linux-x86
PPA
XBMC 9.04.1 r20654
