2009-08-01, 16:36
2009-08-01, 16:47
<visible>Control.IsVisible(id)</visible> or <visible>Control.HasFocus(id)</visible> is possible.
2009-08-01, 17:03
OK, thanks, IsVisible and HasFocus won't do what I am looking for. I'll just have to layout the screen slightly differently.
2009-08-01, 17:26
thedroid Wrote:Is there anything for conditional visibility based on if a button is enabled or disabled?
maybe you can use the same condition that is used to define the enabled/disabled state of the button ?
2009-08-01, 19:49
ronie Wrote:maybe you can use the same condition that is used to define the enabled/disabled state of the button ?
Thanks ronie but it is being enable/disabled from within xbmc itself. Anyway I have sorted it by adjusting the dialog layout.
