Full Version: recently added albums
could someone tell me what the correct "Container.Content()" variable is for this area, i would like to set directly ie not by doing !Container.Content() for all other known areas, just it is not listed in the online manual ?
cheers
andyblac Wrote:could someone tell me what the correct "Container.Content()" variable is for this area, i would like to set directly ie not by doing !Container.Content() for all other known areas, just it is not listed in the online manual ?
cheers
not sure if there's a Container.Content() for it, as an alternative you could use:
substring(container.folderpath,musicdb://6/)
ronie Wrote:not sure if there's a Container.Content() for it, as an alternative you could use:
cheers, i'll give it a go
EDIT: yup it worked Smile thanks
The content type there *SHOULD* be albums, as that's what you have.
If it's not, let us know as it needs fixing.
jmarshall Wrote:The content type there *SHOULD* be albums, as that's what you have.
it not it you set container.content(albums) in:
Recently Added Albums
Recently Played Albums
Compilations
you get nothing
this what i had to do to get everything working.
PHP Code:
<visible>[Container.Content(albums) + !IsEmpty(ListItem.Label2)] | [[substring(container.folderpath,musicdb://5/1/,Left) | substring(container.folderpath,musicdb://5/2/,Left) | substring(container.folderpath,musicdb://6/,Right) | substring(container.folderpath,musicdb://7/,Right) | substring(container.folderpath,musicdb://8/,Right)] + !IsEmpty(ListItem.Label2)]</visible>
r22037 should allow you to simplify your code a bit Smile
Cheers,
Jonathan
jmarshall Wrote:r22037 should allow you to simplify your code a bit Smile
Cheers,
Jonathan
thanks Big Grin
found another one,
Container.Content(songs) is not working whilst your in playlists.
i have to use:
PHP Code:
substring(container.folderpath,special://profile/playlists/music/,Left)
Please add a trac ticket and cc me. Thanks!
